Guest Chris M Posted July 7, 2010 Share #1 Posted July 7, 2010 Advertisement (gone after registration) Can anyone recommend a case that would work out in the surf with this cam? cm Link to post Share on other sites More sharing options...
Advertisement Posted July 7, 2010 Posted July 7, 2010 Hi Guest Chris M, Take a look here Vlux 20 under water case? . I'm sure you'll find what you were looking for!
stuny Posted July 8, 2010 Share #2 Posted July 8, 2010 Chris - The Panasonic site mentions a case for the ZS5 and ZS7. The ZS7 is the equivalent to the V-Lux 20, and the ZS5 is the equivalent without the GPS. If the case is like the one I used for the Panasonic equivalents to the C-Lux 1 and C-Lux 2 it is a well designed case, but you must take care to use absolutely miniscule amounts of silicon grease on the gasket, and be otherwise careful to prevent flooding. You will also need an external flash, a flash arm, an accessory arm, a body base to hold the camera and accessory arm and a fiber optic cable with a sensor at one end to pick-up the V-Lux flash and a connector for the external flash so that the V-Lux flash triggers the external flash. You can see photos from that rig on our site, in the Borneo galleries. Here’s a picture of that rig. The V-Lux rig will no doubt be quite similar. Link to post Share on other sites More sharing options...
