Thumbs Up Coder Kit 2.0
parigby
I have one and use it for my Zeiss 50/1,5. It works perfectly, though if I switch lenses a lot, I'll have to re-mark the code as the marker wears off. Thats a marker problem, not a problem with the kit. Typically it's once per 2 or 3 changes. The price is a bit high for what you get, but the quality of presentation is top notch, but too big to carry around practically. I noted down the notches for my lens and carry the pen and template separately to cut down on size.
It works ok. Nice case. Ofcourse when changing the lens often you have to place the code more times. And there is only a black pen and not a white one. So my APO 90mm didn't get it before I placed a white dot myself.
I found the coder kit great but I didn't have much luck just using the pens. In the end I used the kit to mark the lens flange and then very carefully milled out the markings using a Dremel. I then used Humbrol enamel Matt Black and Matt White to fill in the coding.
I did this some time ago on my 24 Elmarit, 35 Summicron, 50 Summicron and 90 Summicron and it worked just fine. I still need to do the Tri-Elmar (MATE) which I will get round to doing.
Sounds a daunting task but if you're careful it's straight forward.
______________________________________
Regards, Tom
Photography by Tom Lane
How about the screws?
I'm not sure who your question is directed at, but if it was me, from memory, none of the coding marks lined up with any of the screws. However, I'll double-check on that when I get home.
Regards, Tom
Black and white nail polish works very well and does not wear off. Tim Isaac of Match Technical confirmed that I could not use his coder kit on my 90mm Tele Elmarit M because screws lined up with the 6 bit coding location, and other Forum members suggested a terrific work around for this lens. I used both black and white nail polish on one of the screws to approximate the edge of the one black mark in the 6 bit coding (it was, oddly, in the middle of a screw), and the M9 has recognized the lens perfectly as coded since.
Rich
Rich
Mine's a 90 Summicron and so it may have different coding. However, I will check tonight when I get home and let you know.
Cheers, Tom
Cheers, Tom
I did check last night and yes, one of the coding marks fell directly on top of one of the screws. (There are three coding marks together and it falls on the centre one.) As the screw-head is slightly recessed I just painted the top of it matt black. If the screw needs to be removed in future it would be easy enough to remove the paint from the 'cross-head'.
Regards, Tom
