M9 Battery Charger Outside of U.S.
sanyasi
If I use my M9 battery charger outside of the U.S. can I do it with just an adapter (change the plug), or do I need to also use a converter (change the power)? I have been told that for things other than computers and hair dryers all I need is an adapter.
Thanks
Jack Siegel
The charger is specified to work over a range of AC line voltages from 100V to 240V, 60 or 50 Hz. So unless you're out of this voltage range or on high voltage DC all you need is an adapter. The charger will also run from any DC voltage from 12v to 24V such as a car or truck battery via the one pin jack next to the 2 pin line input.
Bob.
Your charger is happy to accept 100V-240V 50/60Hz. The voltage is regulated in the charger. You should not need a separate converter. You will need either a replacement power lead or an adapter for the plug for different sockets only. Those are very common for travellers, of course.
The plug on the charger is totally universal - I have got dozens of those cables from old electronic gear. Even if the appropriate one is missing it is very easy to buy a generic spare one.
The old man from the Age when electricity was obtained by energetically rubbing two cats against each other
Lars: Thank you, that was one of your best ever. Now I can truly face the day with a smile on my face! :D
Thanks to all who responded. I will have to check the box for the European cord, although I will be in Australia.
Jack Siegel
All you need is a "figure 8" cord with the right plug.
Jack Siegel
Jack, no problems. Lots of M9 chargers in use here with a standard appliance cord in the socket. We get the same charger as other markets but Leica Camera varies the included leads. You can pick up a lead for a few dollars or just use a plug adaptor if you already have one.
The new compact charger is a lot more convenient than the old (first m8) design where you had to swap out a plug module.
Most likely you will have more than one device that needs charging during your visit. Many laptop chargers/razors etc will not require any voltage regulation. Naturally you don't want to connect 240V to an old dumb device though.
Actually, my old physics textbooks talk of rubbing a stick of amber with a cat skin. I don't think that rubbing two cats against each other will get you anything but scratches!
