camnoj Posted June 22, 2010 Share #1 Posted June 22, 2010 Advertisement (gone after registration) Having bought an M8 earlier this year, WOW what a camera but . . . I have two lenses a CV 28mm f1.9 and a CV 50mm f1.5 I have coded both lenses with a Sharpie and they work indoors when I test them . However when I take them outdoors to use in broad daylight the coding no longer works. If I return into the house the coding works. Am I missing a trick? I have a Leica 75mm which is coded this lens works fine indoors or outdoors so I'm reasonably sure it's not the camera. Link to post Share on other sites More sharing options...
Advertisement Posted June 22, 2010 Posted June 22, 2010 Hi camnoj, Take a look here Manual Lens Coding - am I missing a trick?. I'm sure you'll find what you were looking for!
jaapv Posted June 22, 2010 Share #2 Posted June 22, 2010 Are those LTM lenses on a adapter ring?In that case light may leak onto the diodes. Link to post Share on other sites More sharing options...
camnoj Posted June 22, 2010 Author Share #3 Posted June 22, 2010 Hi Jaapv Thanks for the quick reply I have looked at the adapter and they are on the correct adapter but there is a 1mm gap between the camera body and the lense adapter face that is closest to the camera body. Therefore light can flood into the area where the diodes are located. Is there a graceful way around this problem or is it a matter of apply a bit of tape to keep the light out - a messy solution? camnoj Link to post Share on other sites More sharing options...
jaapv Posted June 22, 2010 Share #4 Posted June 22, 2010 The most elegant solution is of course to get a couple of Jonh Milich's adapters with coding dents. Link to post Share on other sites More sharing options...
camnoj Posted June 22, 2010 Author Share #5 Posted June 22, 2010 Can you point me in the right direction? Link to post Share on other sites More sharing options...
jaapv Posted June 22, 2010 Share #6 Posted June 22, 2010 Cambrian Photography Ltd items - Get great deals on Photographic Accessories, Batteries items on eBay.co.uk Shops! And John (JLM I believe in this forum) himself. Link to post Share on other sites More sharing options...
camnoj Posted June 22, 2010 Author Share #7 Posted June 22, 2010 Advertisement (gone after registration) Thanks for your help Jaap Link to post Share on other sites More sharing options...
camnoj Posted June 22, 2010 Author Share #8 Posted June 22, 2010 Coming from an engineering background an alternative but not so graceful solution is an elastic band around the base of the lens before engaging the lens into the bayonet protects the diodes from direct light and presto it works. Thanks for the explaination of what the problem was without your help I wouldn't have solved it. I might still splash out on a Milich adapter some time. If anyone wants to know how I solved the problem and can't understand my sketchy description drop me a line and I'll upload a photograph. Otherwise once again many thanks Jaap. Link to post Share on other sites More sharing options...
parigby Posted July 1, 2010 Share #9 Posted July 1, 2010 I can confirm that the Milich adaptor is the elegant way to go, having obtained one for use with my CV 15mm. Excellent results from both the adaptor and lens. Link to post Share on other sites More sharing options...
bocaburger Posted July 1, 2010 Share #10 Posted July 1, 2010 I use Leitz LTM-M adapters on 15,21,28 and 75 C/V lenses plus a Nikkor and of course Leitz LTM lenses. No gaps. There are 2 types of adapter however, one with just 3 little cutouts around the rim (for the unscrewing lugs found on old rear plastic caps) and another with a large area cut away. The latter is unusable for coding because the area that needs the code is where the cut away is. I also coded a couple of Cosina adapters (type II, without that unfortunate cut away) for a friend, with no gaps and no problem. Link to post Share on other sites More sharing options...
