adli Posted May 27, 2010 Share #1 Posted May 27, 2010 Advertisement (gone after registration) What has happened on this file? I am not talking about the blurriness due to the slow shutter speed, but the fact that the picture is cut in two, with a color cast on the left side. Nothing like it on any of the other files. Seems as half of this file has been processed differently in lightroom than all the other files. File is straight out of Lightroom with default settings. Anyone can explain this? Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2010 Posted May 27, 2010 Hi adli, Take a look here strange artifact on raw file. I'm sure you'll find what you were looking for!
jaapv Posted May 27, 2010 Share #2 Posted May 27, 2010 This is the centrefold problem. Somehow the amplifiers of the left and right sensor readout were out of step. If it recurs the camera will have to have its electronics seen to in Solms. Link to post Share on other sites More sharing options...
okram Posted May 27, 2010 Share #3 Posted May 27, 2010 It also occurs sometimes an never again, or rarely.I have seen it once, and never again. Wait if you see it again. Over 320 ISo, methinks. Link to post Share on other sites More sharing options...
meino Posted May 28, 2010 Share #4 Posted May 28, 2010 I had once also a very strange problem with an image, where one half of the image was different. It was more pronounced then yours. However in my case I remembered the circumstances. I was busy during a party taking pictures, and suddenly my M9 was dead, with a totally flat battery. After replacing the battery, the M9 was fine again. However the last picture I took before the M9 went dead was the corrupted image. I didn't bothered to much because I realized that I had been continued taking pictures while the battery was low and it probably went dead while the corrupted image was taken. Regards Meino Link to post Share on other sites More sharing options...
adli Posted May 28, 2010 Author Share #5 Posted May 28, 2010 Well, in my case, the battery was not dead. After this picture I shot an other 13 pictures of the same sky. Only one of them shows the same effect, but weaker. However many of the shows an other interesting phenomenon, two moons Must be some kind of flare? Link to post Share on other sites More sharing options...
Xmas Posted May 28, 2010 Share #6 Posted May 28, 2010 You are not using an IR filter? Noel Link to post Share on other sites More sharing options...
adli Posted May 28, 2010 Author Share #7 Posted May 28, 2010 Advertisement (gone after registration) You are not using an IR filter? Noel Well, actually, this is the only lens (90 cron) where I have left the filter on after I sold the M8. Link to post Share on other sites More sharing options...
mjh Posted May 28, 2010 Share #8 Posted May 28, 2010 Well, actually, this is the only lens (90 cron) where I have left the filter on after I sold the M8. That would explain the second moon. Light is reflected off the sensor and and back into the lens, then reflected off the filter so it hits the sensor for a second time (but mirrored horizontally and vertically). Link to post Share on other sites More sharing options...
