dritz Posted December 27, 2006 Share #1 Â Posted December 27, 2006 Advertisement (gone after registration) Just acquired a new R9 -- primarily to have TTL flash while shooting in M mode (and will soon sell an R8 chrome). However, I still get "Hi" in the viewfinder after the exposure and overexposed slides. Am I missing something here? Isn't the R9 behavior supposed to be like the M TTL? That is, set the aperture and exposure to ambient light then let the TTL flash (SF-20) do its thing (minus a stop or two)? Â Really, with TTL should I ever see "Hi" after a TTL exposure? Â Dean Quote Link to post Share on other sites More sharing options...
Advertisement Posted December 27, 2006 Posted December 27, 2006 Hi dritz, Take a look here R9 and flash. Should I ever see "Hi". I'm sure you'll find what you were looking for!
robsteve Posted December 27, 2006 Share #2 Â Posted December 27, 2006 Dean: Â If you are closer than the close working distance of the flash you will see HI. Such as shooting wide open at 800asa and up close. The range will be in the flash manual or the camera manual. Â Also, when shooting a TtL or auto flash, do not use the F setting. It will give an error there, as it is expecting a manual flash to meter. Â Are you using the R9 with film or digital? Quote Link to post Share on other sites More sharing options...
rick_dykstra Posted December 27, 2006 Share #3 Â Posted December 27, 2006 The R8 has TTL in manual. I use it all the time. However, the camera isn't magic and might not be able to throttle the flash quick enough if too much flash power is provided. So, consider the shooting distance and dial the flash down to a little more than that - then TTL will work - depending on the reflectivity of the subject. :-) Â TTL also works in manual mode with the R9, though like the R8 it will still show HI if too much flash is provided. Â The M6 TTL is particularly good at throttling flash. The R6.2 is not, even though it too has a TTL circuit. Â Rick. Quote Link to post Share on other sites More sharing options...
dritz Posted December 28, 2006 Author Share #4  Posted December 28, 2006 Dean: If you are closer than the close working distance of the flash you will see HI. Such as shooting wide open at 800asa and up close. The range will be in the flash manual or the camera manual.  Also, when shooting a TtL or auto flash, do not use the F setting. It will give an error there, as it is expecting a manual flash to meter.  Are you using the R9 with film or digital?  I think you're right about my being too close to the subject and fast film (How did you know that I was shooting HP5 at 800 ASA?) I am using (amusing?) it in M mode, but will experiment more to understand the boundaries of the R9 with fill flash. In that way, the R9 flash is not quite as predictable as a TTL M body.  Thanks for your excellent points. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/12165-r9-and-flash-should-i-ever-see-hi/?do=findComment&comment=128225'>More sharing options...
dritz Posted December 28, 2006 Author Share #5 Â Posted December 28, 2006 Forgot to document that image. No flash on this one... hoping to to use the flash for such natural looking portraits when the ambient light is too contrasty. Â R8, 80 Summilux, HP5 at ASA 800, cross processed by dr5.com. Nikon 8000 scan, no sharpening. Quote Link to post Share on other sites More sharing options...
