markpsf Posted April 7, 2010 Share #1 Posted April 7, 2010 Advertisement (gone after registration) I'm aware that a UV/IR filter is not needed for lenses with the M9. I have a couple though because I formerly used the M8.2. I have two questions: Will it be detrimental to use these filters with the M9? Do you use a protective filter with your Leica lenses when using the M9? Thanks. Mark Link to post Share on other sites More sharing options...
Advertisement Posted April 7, 2010 Posted April 7, 2010 Hi markpsf, Take a look here UV/IR Filters and M9 - Advice Needed. I'm sure you'll find what you were looking for!
jaapv Posted April 7, 2010 Share #2 Posted April 7, 2010 1. On longer lenses than 35 (50) mm it is no more detrimental than any other filter. 2. Sometimes, when needed. Link to post Share on other sites More sharing options...
markpsf Posted April 7, 2010 Author Share #3 Posted April 7, 2010 Thanks. What about for 35mm? My three lenses are 28, 35, and 50mm. And you also say "no more detrimental". Are you generally in the "skip a protective filter" camp? Mark Link to post Share on other sites More sharing options...
jaapv Posted April 7, 2010 Share #4 Posted April 7, 2010 Yep- I am. I favor lens hoods and insurance The 35 you must just try, watch the color shift towards the corners. Link to post Share on other sites More sharing options...
Ed_K Posted April 7, 2010 Share #5 Posted April 7, 2010 According to Leica, those filters are bad idea for the M9, here's a screen capture from its manual :- Link to post Share on other sites More sharing options...
jaapv Posted April 7, 2010 Share #6 Posted April 7, 2010 " particularly using wideangle lenses" It is OK for longer focal lengths, even mandatory if you want to avoid the last vestiges of IR contamination. Link to post Share on other sites More sharing options...
victoriapio Posted April 7, 2010 Share #7 Posted April 7, 2010 Advertisement (gone after registration) I can confirm what Jaap says about color shift on wide angles with the IR filter on the M9. On a 21 elmarit the corners take on a blue tint O.C. Garza Link to post Share on other sites More sharing options...
Shade Posted April 7, 2010 Share #8 Posted April 7, 2010 No, I don't use the UvIRs on my M9, they create green blobs/reflections at night when there's light sources.. I can't be bothered taking them on and off all the time. So I just screw on my uv filters. Link to post Share on other sites More sharing options...
lars_bergquist Posted April 8, 2010 Share #9 Posted April 8, 2010 The UV/IR filters made for trouble with light sources in the picture creating green reflections of themselves. No filter at all is theoretically best; Leitz used to say so, and the number of old Leica lenses which have cleaning marks on their front surfaces is amazing! There is no discernible disadvantage to using a UV filter, and it does protect that front surface. Leica lenses are still slightly more expensive than Leica filters ... With lenses that are well protected by a rigid hood and a slip-on cap, I forgo filters. This also makes a polarizer faster to use -- no filter to remove first. With lenses with extendable or shallow hoods, I feel safer with a filter on them. The old man from the Age of the Yellow Filter Link to post Share on other sites More sharing options...
jpattison Posted April 8, 2010 Share #10 Posted April 8, 2010 You feel safer! I guess your lens does to! Cheers, John Link to post Share on other sites More sharing options...
