24 OR 28 mm
leica-steph
Hi everybody,
I received my M9.. in Geneva...! incroyable!
ok, it's my first M. I bought a 50 Summarit 2.5... for price.
I've to buy a wide angle... I've got a R7, and I use a 28mm principaly.
I'd like a 24 or 28.
What do you think, what is the best I could choose?
Thanks a lot and have a nice day.
PS: le M9 is a very beautiful machine, very simple and easy to bring!
Tough to answer this one because it kind of depends on so many factors depending upon the lens range you intend to use with the camera overall, plus obviously your comfort with the 24 or 28mm focal lengths.
Both will be wide on the M9, 24 especially so. 28/50 is a classic pairing but it really depends on what you like. If you like that focal length with the R then maybe it makes sense for the M9 too. Some people like to have more "space" around the image with RF shooting so might prefer the 24. Remember also that the 28mm can be easily framed in the viewfinder without the need for an external VF.
I'll second Graham's suggestion. Especially if you are new to the M (and probably to rangefinder cameras in general) the extra distraction of an external finder may be too much. So it should be a 28. If you are positively rolling in money, get a Summicron ASPH.
On the other hand, coming fresh from the SLR world which is a different planet really, I would advise you to get one lens first, and really learn to use the camera with that lens. RF people do not play around with lots of different focal lengths, really. Henri Cartier-Bresson used a 50mm Summicron nearly exclusively. When you have mounted a lens that you know really well, you also put on the 'eyes' for that focal length, and you see the pictures before your eyes before you even raise the camera. HCB did that. And Winogrand. And just about every famous Leica photographer. Learning that trick will make you a better photographer too.
But allow me to point to a little lever on the camera front. With this, you can switch finder frames at will and get to know the framing of any lens from 28 to 135mm -- without even buying it. So you can play along with a 'virtual 28' or a 'virtual 35' to your heart's content, until you have an idea of what you really want.
The old man from the Age of the Brilliant Finder
Respectfully disagree: 28 mm lines are hardly visible for me, wearing glasses. Anyway, the choice of FOV is very individual. I was used to 28 mm equivalent from my other cameras, and went for the Elmarit 28 Asph.
If you don't wear glasses, I'd say go for the 28 without a doubt. You say 28 used to be your most used focal length AND you can see the frames in the finder. Win-win if you ask me.
If you wear glasses and/or have problems seeing the 28 framelines, and you will be using an external finder anyway, there could be reasons to go to 24/25mm. It's not that much wider, and there are some very nice 24/25mm lenses out there that do things some of the 28's don't do. For example, the Zeiss 25 is very sharp and Leica has a 24/1.4.
28/50 is a great lens pairing IMHO, and you can't go wrong with the 28 Cron Asph. Two weeks in Santiago de Cuba and the 28mm practically lived on the M9. Not the sharpest lens Leica makes for the M-series (the 24/2.8 Elmarit Asph is noticeably sharper), but certainly one with plenty of character and smooth tonal transitions.
