Summicron-R 90 filter size?
Hi, does anyone know if it's possible to use a step-up ring with a Summicron-R 90mm (v1, 2-piece lens hood, 1977)?
I'm a bit confused about the info on the filter thread size that I've found. Is it an E55 or a Series 7, or is my info completely wrong?
Any help would be appreciated.
x
This is often confusing. The v1 90mm Summicron was designed to use Series VII filters held in place by ring 14161. The actual threads on the lens are 54mm. Close-ups utilize Elpro VIIa. From lens #2770951, the thread size was changed to the more standard 55mm so that E55 filters are used, and the Elpro 3 for close-ups. I'm not sure if anybody makes a 54-55mm step up ring. True Believers have long accepted that Leitz does this stuff to test our faith.
