C mode
SiOnara
If you don't want to accidentally go into C mode when using the discreet shutter option I found the below item on eBay thats rather useful.
A set of these self adhesive rubber pads measuring 7.5mm.
They are clear and stick nicely over the C position making it near impossible to accidentally pop the camera onto C mode. I also found you can turn the camera on faster as the switch automatically stops on the S position.
Obviously this puts a spanner in the works if you want to take a self timer shot but since you get 75 feet for £4! you can easily remove it and pop another one on.
Jei
Self-Adhesive Rubber Feet Hemispherical Small Clear (75 on eBay (end time 04-Mar-10 02:02:51 GMT)
x
That's what I did...
If you find soft clear silicon feet intended to protect tables from scratches and place it right up against the switch over the "C" it will prevent you from accidentally going into it. I found some "feet" that was soft enough that I can still (with a little effort) get into self timer mode.
