Does C1 display f-stop information for M9 images?
kidigital
Thanks Ario. For some reason, I'm not getting an estimated value (lenses are coded and very new). I just tried polishing the sensor that reads the coding and wiping off the codes ... but that's not doing anything either.
Kurt
Version 5.1 of C1 did the trick .... the estimates are bit off, though, especially on the new Noct.
Kurt, update the firmware and see whether it gets better. Supposedly, one of the issues that Leica addressed with the new firmware is the max f/ value of that new Nocti lens. Since the estimated value is based on the max value and that is off with the previous firmware, then the estimated value would be off, too. I hope the new firmware will fix this particular issue.
On a different note, you made me think about this lens.... Bad, bad bad :D.
