sjt1 Posted March 6, 2010 Share #1 Posted March 6, 2010 Advertisement (gone after registration) I am contemplating doing the fix mentioned in this post from 2007. In the post it mentions using "thermally stable PTFE grease". I haven't got any of that, but I do have some silicone grease. Could anyone with knowledge of such things advise me on whether silicone grease would be OK for lubricating the shutter button after the polishing mentioned in the post? I have just looked at the tube and it says that silicone grease: has high electrical insulation waterproofs / repels moisture has high temperature resistance so to my mind it sounds like a good solution. Anyone care to comment on anything that would make it a bad idea? Thanks in advance Link to post Share on other sites More sharing options...
Advertisement Posted March 6, 2010 Posted March 6, 2010 Hi sjt1, Take a look here Type of Grease for Rough Shutter Release Fix?. I'm sure you'll find what you were looking for!
marknorton Posted March 6, 2010 Share #2 Posted March 6, 2010 Don't do it. In spite of all the comment about the release button machining, the grittiness in my experience comes from the adjustment of the shutter release switch. You'll find a thread where I explain how to do it. I certainly don't recommend using a grease which may or may not be appropriate. Link to post Share on other sites More sharing options...
gravastar Posted March 7, 2010 Share #3 Posted March 7, 2010 Don't use silicone grease, at least not the commoner kinds. They can creep like crazy and go places you don't want them. They are a very good electrical insulator - so you don't want them near the switch. Also if there's any trace of sparking they form insulating metal silicides on switch contacts. Bob. Link to post Share on other sites More sharing options...
sjt1 Posted March 7, 2010 Author Share #4 Posted March 7, 2010 Thanks both for the replies. I think I will leave it well alone! I am glad I asked as there is good advice here. Thanks again Link to post Share on other sites More sharing options...
fotoism Posted March 7, 2010 Share #5 Posted March 7, 2010 .....You'll find a thread where I explain how to do it.... Would you mind pointing to this thread? Thanks! Link to post Share on other sites More sharing options...
menos I M6 Posted March 9, 2010 Share #6 Posted March 9, 2010 Don't do it. In spite of all the comment about the release button machining, the grittiness in my experience comes from the adjustment of the shutter release switch. You'll find a thread where I explain how to do it. I certainly don't recommend using a grease which may or may not be appropriate. Silently disassembling shutter release button asslembly again, removing grease (very, very small amount, just on the one upper polished contact surface, which showed slight wear on one side). And it felt sooo much better slightly greased Mine was not just "gritty feeling" before the operation - I often just slipped from AE lock to shutter release without proper distinction of the two steps - surely a downgrade in feel from a M6 classic. Thanks for the warning and insight - I appreciate that. Link to post Share on other sites More sharing options...
