Looking for larger bag (I am going photo)
Jerry_R
And if you want something smaller, the Think Tank Urban 20 works great for one body and 2+ lenses (I currently have a 35mm and 75mm f2 and loads of room to spare). I figure it will work for up to 4 lenses depending on their size. Even the 75 f2 standing on end fills only half the depth of the bag, so the lenses will get stacked.
I've used it for a couple of weeks and am very happy with it.
Just had a quick look, it seems to be high, so you put things one on top of others, right?
But if access is only from top, isn't it difficult?
The UD 40 is only about 3cm taller than my Billingham Hadley Pro, so not very tall.
You can stack lenses on top of each other with dividers in the UD40, but when you take a camera out of the bag that space is open for you to spread your lenses into. Additionally you could have the camera (or each camera) on top of a lens, separated by dividers. So you can still get at everything when shooting. Make three main compartments, one lens under each camera in compartments 1 & 2, one lens on top of another in 3, and two on the cameras, thats six lenses. Even with Leica M's thats a fair bit of weight to lug around and you may need less equipment than that anyway. You can of course stow lenses in other pockets of the bag if you don't want to go into the main compartment.
But if you need to see them all, all of the time, I don't think you would find a bag unless you stick to full on DSLR size bags.
Steve
