M8 Battery or Power Problem?
burkey
Hi Folks,
This morning I noticed that when I turned on my M8 with a freshly charged battery the LCD frames and battery power window wouldn't light up. After playing around the camera for a while I also noticed that if I pushed the shutter button down half way the camera would sort of "wake up", i.e. red light on the back lit up as well as the frame/battery power window too.
I tried both the original battery as well as an after market one. Both did did the same thing. Admittedly the Leica battery is at least three years old.
So, should I try a new Leica battery before I send the body down to NJ for a "look over"? Your opinions are, as always, appreciated. Thanks in advance.
. . . David
I and others have had this plroblem.
It has something to do with the swtich and the electronics in the camera. It seems to go into sleep mode, or maybe stays in deep sleep mode (Off), as soon as you turn the camera on and only wakes up after pressing the shutter release.
There is no fix for this by the user. It has to be sent back to Leica for repair or just use it as it is.
