GGS pro screen protector
Snakepottery
but can't seem to find one for the M8.
What do others use? Or nothing at all?
Ta.
Thy're readily available on ebay from the US. $3.60, plus $4 P&P to the UK.
I've sourced two from them and it takes a week to deliver.
I bought and use an ES screen protector which does not stick to the LCD screen but is held on by the vacuum created between its gel like surface and the screen.
There are no air bubbles and it seems invisible in use to me.
I felt safer with this than with glass, which I felt could break and scratch the screen, or damage it (or me). There are no air bubbles and it can be lifted from one corner without seeming to pull the LCD cover - some users have had difficulty with self adhesive protectors removing the cover and exposing the actual LCD.
It arrived quickly and was less than £4 including post.
ES Screen Protector
I'm using GGS, too; overall, I'm most pleased with them with one exception: in moderately warm climate (SE Asia, ~≤30°C, rainy season), the glue strip tends to get extremely weak and the entire thingy starts to shift, leaving a significant trail of residue while doing so.
Just received a replacement last week, hope that it was only an issue with the previous batch...
Best regards,
Michael
P.S.: Leica CS recommends alcohol for cleaning of the screen which worked extremely well!
