M9-Metering system
david berry
x
It is explained in the brochure:
Exposure metering: Exposure metering through the lens (TTL), center-weighted with working aperture. Center-weighted TTL metering for flash exposure with system-compatible SCA-3000/2 standard flash units.
Measurement principle: Measured by light reflected by bright shutter blades on the first shutter curtain.
The reflected light is measured by a photodiode below the lens mount. I guess it is comparable to the D3's center-weighted metering mode except for the exact shape and weight of the central area which for the M9 looks like a squashed oval covering roughly the central 25% of the view, and is fixed. I am sure someone has more precise figures.
The best way to use it is to go to manual and measure the darkest and lightest areas of the image and determine your exposure accordingly. Refer to the manual for the use of the red triangles in the viewfinder. If you are lazy just go to "a" and trust the camera.....
I'm lazy, I point the camera at a midtone - such as grass for example - and lock the exposure on that. If the light is difficult, then I agree manual with some educated adjustment is best solution. With the amount of snow we've had in the UK recently I overexpose to prevent everything looking grey.
Can someone explain how the M9 metering system works ? The leica metering system works very different than a Nikon D3 or other DSLR's system...Trying to understand how to meter different situations..
Thanks for your imput
I don't know about a Nikon D3, but, somewhere deep in the darkest depths of the menu system, I have managed to make my D700 shutter button work like an M7's... And just like an M9 will do. The D700 also gives three different metering patterns. Maybe the D3 does too.
Take a meter reading, hold the button down half way to lock it, recompose and shoot. Intuitive, simple, and works very well, on both the M7 and the D700.
I love my D700, but for some reason I find this scary. And it can be done with less than three buttons? If you find out how, please enlighten us. Now that I am with an M9, I find I am suppressing my past...
See page 296 of the D700 manual. It's custom setting C1. Set this to 'On' and the exposure will lock when the shutter release is pressed halfway. You can also adjust the size of the centre-weighted area to more closely match the pattern of an 'M' camera by using custom setting B5. :)
