Telyt 400/6,8 R-mount to Visoflex
Is it possible to use R lenses, in this case a Telyt 400, on my Visoflex III + M9 combo?
I know the best thing is to look for a Telyt with a Visoflex M mount but could this also work
with the R to M adaptor nr 22228 ??
Any experiance, anyone?
x
The 22228 is made to fit a Leica R lens on a M body - directly, not with a Visoflex attached, so it isn't a viable solution for a long Telyt : no way to focus apart infinity.
Remember that the thickness of M body + Viso II/III is GREATER than R body, so in general a R lens can not be adapted for Visoflex (while Visoflex lenses can be mounted on R, and a proper accessory did exist).
Which kind of 400 is yours ? If it is a f 5,6 version I think the only way is to have the proper "Televit" unit (code 14136) : the 5,6 Telyts were made of 3 units : Televit (with handle) - diaphragm unit - lens unit, and only the first is different from R to Viso version.
A quick surf made me find one available here :
http://www.foto-hobby.de/fhr-e/leica-various-used-items/leica-spare-parts/leica-televit-m-spare-part.html
Which can mean is not an impossible item to find.
The 400 & 560 f 6,8 are made in a different assembly , 2 parts only : focusing unit and lens unit (this one is the same for R and V version) : at the moment I do not remember exactly if the focusing units were separately coded... but I am sure that my 400 6,8 has a Viso mount at its end, with an adapter that allows to mount it also on R body.
Thank you both for the fast and good advice on this subject. It probable also explains
the reasonable price of the lens unit.
I'll scout the internet for the proper Telyt or Televit that will fit my Visoflex.
the Televit ist interesting, you can use the head of the Telyt 280 too...;)
