Bag for DMR
robert_parker
The R9 / R8 DMR is a great camera but it's not that easy to walk about the place with one slung round your neck - what camera bag / case do DMR users to keep their camera + say a couple of lenses (might be a 180mm 2.8 + 35-70mm Zoom) ??
x
Robert -
I use a small backpack with the camera in a soft drawstring bag and the lenses in their cases. It doesn't look like a camera bag, and is therefore less attractive to thieves.
Stuart
Guest stnami
Here way down in the southern hemisphere we use tucker boxes and thunderboxes to lighten the load
try the jolly jumbuck brand
I'm using a Billingham 206 bag with a 9-12 S-Flex insert.
This arranges the interior perfectly to hold the R-8 with DMR attached (or motor drive) and either a 70-35mm or 21-35mm lens on the camera. The S-Flex is sized to just hold a Metz 54-MZ3 and a 70-180mm standing upright. There is sufficient room to easily retrieve and replace the camera, lens and flash without banging them about each other.
If need be (and your back can support it) an AVEA-6 detachable outside pocket will carry either of the shorter lenses mentioned above with room for a 2X Extender-R. If you are looking for real punishment you can attach a second AVEA (for water and rations) and strap your tripod on the bottom of the bag. All the while having two front expandable, covered pockets for cleaning supplies, memory cards, etc. and a wide shoulder strap that is quite comfortable.
I use a Domke F4AF for my R9/DMR. It also fits this stuff:
35-70 f4
21-35
80-200 f4
Metz 54 with off camera cord
Hyperdrive 120GB
Spare DMR battery
60mm & 67mm filters
Charger for DMR
Gary Fong flash difuser
Robert,
I'm using a LowePro Daypack which carries the R9DMR, 3.5-4/21-35, 4/35-70, 4/80-200, charger, batteries, remote-control and several filters and other accessories.
By the way: The most important thing I did to increase the carrying comfort was to replace the regular strap with one from Op/Tech.
Stuart, iM, Thom, Albert, Daniel, and Wilfried
Thanks for your ideas and input - I think I'm most probably going to go down the Billingham 206/306 route, though Luigi's cases do becon if you're using anything like a standard lens !!
Ps iM - I've used Tuckerboxes before now to carry cameras but I don't think I'll risk the Thunderboxes - most of my photographs wind up in there anyway !!
:p
Guest guy_mancuso
I'm a wimp . i use a Tamrac digital rolling bag , very similar to a Lowe Pro roller 1. I have no back left after this many years carrying gear. I can get 2 DMR/9 15,19,28,35,50,80,100,180 f2, batteries and cards and a metz 54 flash. i just can't fit the 280 f4 in with the 180 f2 at the same time. Oh and the 1.4 extender. Plus cords, Color Chart and little items.
Robert, FWIW . . . I bought my Billingham through Robert White (UK) by mailorder to the U.S. They were less expensive, had full stock of all the pieces I wanted, shipped right away and were courteous, prompt and personable in emails.
Best!
Thom
