sd card storage
geesbert
x
what di you use for your sd-cards?
I need space for 4 cards
stefan
Stephan, here are two quick pictures of mine. Unfortunately they bear no name but I think I bought them from 7DAYSHOP.COM. If you look at that site you will see a wide selection, some in aluminum cases; most are very cheap but functional. I find a case for four cards more than adequate for most jobs. On tour I keep more cards in their plastic cases and transfer the ones I need to this case. When used, I lock them and invert them for easy identification.
now I remember, I bought one of those for CF cards from 7dayshop a couple of years ago. that was the cheapest place to buy film (remember film?) at the beginning of the millennium....
I use the gepe card safe. cards are numbered 1-4 and when they come out of the camera I put them back in the card safe back to front so that I know that they are used. When I upload to the computerIalways leave them as is until I'm ready to use them again so that if Ilose images off the pc before I back up then I have the images still on the card. I format a card as I put it in the camera.
Sounds complicated but an easy workflow and the card safe really adds a level of security.
We follow a similar procedure except that I make a practice of backing up downloaded pictures to an external hard drive BEFORE I reformat my card in camera. I prefer to do this sooner rather than later because if a few days elapse, it is easy to forget which pictures are already within the computer system.
