21mm summilux on M8.2
clam2033
Do you have the lens detect function on? It may not be reading the 6-bit code. I have a uncoded 28mm Elmarit and the EXIF data says that it is a f/1 max aperture. Are you getting the proper focal length in your EXIF? Post a pic with it and I'll take a look.
Leica lens reviews and technology thoughts...
Omaha, NE Based Photography — Daniel Valente Photography
When I use my 35 f/1.4 pre-ASPH and use the M9 menu to identify it, it comes up as "f/1.0" in ACR EXIF, even though the full name description right above it says "Leica 35mm Summilux f/1.4" - in some cases it even identifies a "Leica Summicron-M 35mm f/2 (IV)" as "f/1.0."
Heck, I just found a shot ID'd as a "Summicron-M 35mm f/2 (IV), where the EXIF also says the exact aperture used for the shot was "f/1.5"
=8^o
