hjernemadsen Posted November 26, 2006 Share #1 Posted November 26, 2006 Advertisement (gone after registration) Maybe a trivial question, but anyway: In the display om my leica M 7 there is a red dot in my display that indicates activation of the metering memory lock. UNDER this red dot there is another red dot (an error messenger dot) that indicates erros of different kinds. This lower dot for example lightens up if I turn the camera on with no film in it. This lower dot (the error messenger dot) is now blinking intermittently when I activate the meter memory lock (press the release buttom half down). The dot is only blinking when I press on the release buttom, it is only intermittently, and it is far from always it happends. As far as I can see the camera funtions. What can it be? I can find no reference to it in the manual Yours sincerely And thank you in advance Peter Lund Madsen Link to post Share on other sites More sharing options...
Advertisement Posted November 26, 2006 Posted November 26, 2006 Hi hjernemadsen, Take a look here Blinking red point in display . I'm sure you'll find what you were looking for!
Guest Seb V Posted November 26, 2006 Share #2 Posted November 26, 2006 Maybe a trivial question, but anyway: In the display om my leica M 7 there is a red dot in my display that indicates activation of the metering memory lock. UNDER this red dot there is another red dot (an error messenger dot) that indicates erros of different kinds. This lower dot for example lightens up if I turn the camera on with no film in it. This lower dot (the error messenger dot) is now blinking intermittently when I activate the meter memory lock (press the release buttom half down). The dot is only blinking when I press on the release buttom, it is only intermittently, and it is far from always it happends. As far as I can see the camera funtions. What can it be? I can find no reference to it in the manual Yours sincerely And thank you in advance Peter Lund Madsen Peter, nothing to worry about. The second dot flashing means you have no film in the camera. Sometimes, even with film in the camera, I get an itermittent second dot when my nose presses against the ISO dial. This doesn't really happen any more. Seb. Link to post Share on other sites More sharing options...
hjernemadsen Posted November 26, 2006 Author Share #3 Posted November 26, 2006 DEar Sebastian Thank you so very much for your ansver. I´ll keep my nose a little more for my self in the future Sincerely Peter Link to post Share on other sites More sharing options...
