Soft Shutter Release Button
wilfredo
I just got a Leica Time soft shutter release button from Luigi and I wish I had done so three years ago when I got my M8. I highly recommend it. The shutter release ergonomics is much improved for only $19.00. I'm leaving it on the camera permanently and only removing it if I have to use a cable release. Go Luigi!
To find these buttons do an ebay search for: S/STEEL SOFT RELEASEfor LEICA M2,M3,M4,M6,M7,MP,M8,MORE
x
Do you lose the exposure lock (second shutter button position) with that soft-release like you do with the Tom A. release? Does it have a tendency to unscrew itself?
You don't lose the ability to use exposure lock. I do it all the time with my soft release. You just need to be more careful about how far you press down on the shutter release.
Wilfredo, did you get the convex or the concave one?
...take care you turn the camera off before stowing it in a bag, or you will get a "hot M8" or a card full of blank pictures. The release makes the shutter button very sensitive.
I do not use a softie on my M8 ( notchy..) but do use it on my film Ms. I use a rubber hair band to prevent the shutter from being depressed in my bag. Tie the hair band through the strap rug and then pull it over the softie and leave it around 'the neck' of the softie.
m
m
Very creative!
I tried a small Nikon convex, matchteck cocave and convex. They all impede the exp. lock. Thanks for the tip. I no longer use them. Thanks for the tip.
Earlier this year, I had the priviledge of meeting Tim Issac in person when he delivered one of his Mini Bip soft shutter releases and CSEP4 Thumbs Up devices, the Bip which I have installed with a small drop of Loctite 222 to keep it from unthreading itself. This Loctite product is for small fasteners and does not require heat or excessive torque to break its hold.
Here's his website: match Technical Services - Beep - Boop - Bip - Bug
Does the loctite solve the exp lock issue? Thanks.
...there's no way a soft release can impede the shutter button function...
The "no exposure lock" complaint is made in several other threads. Just something to be aware of, that the soft release CAN interfere with the intermediate positions, but it does not do so necessarily.
I use the releases and am a little lost without them.
Yes my small Nikon concave seems to be best. Is it the same for the M7? Just curious.
