Showing results for tags 'thumbs up ep-lq2'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. I am looking for a thumb support for my Q2; the two best choices seem to be the Leica Q2 Thumb Support #19543 ($225 USD) and the Match Technical Thumbs Up Grip #EP-LQ2 ($143 USD). The Leica #19543 looks like it is a bit smaller and perhaps less clunky than the Match Technical #EP-LQ2, although it is hard to really tell from the photos I see online. There are other thumb supports that have sort of a hinge in the middle of them, allowing them to be moved but I like the stability and solid construction that the one piece thumb supports like the #19543 and the #EP-LQ2 offer. There is a price difference of $82 USD between the two which is a secondary concern; I am interested in getting the best thumb support, not the cheapest. After much thought, I'm beginning to wonder if the Leica thumb support is actually $82 USD better than the Match Technical thumb support, and if the Match Technical is really that much larger than the Leica thumb support. If you have used either (or both) of these thumb supports, hearing your insights would be greatly appreciated.
