Showing results for tags 'sf 24d'.
	I am posting this in anticipation of delivery of a Leica SF 24D flash. Battery type to use is CR123A 3 volts. Does anyone has experience using rechargeable batteries. As I understand most rechargeable batteries do not have similar voltage and is crucial to proper operation of the SF 24D.
	Hi, I wonder if others had the same problem: I have a 2nd SF 24D that I use regularly with my M3 on A setting, no problem. Now, recently I obtained an M9 and tried out the 24D with it but it instantly switches to a flashing ISO 3200 and an LGN of 45. This cannot be changed by the +/- buttons, nor anything else (such as f-stop). This occurs in A and M setting (TTL/GCN I can forget - it doesn’t work at all with the M9 but reminds me to switch to A). The odd thing is that it resets once off the M9 and then the settings can be used just as normal. I tried it also on a friend’s D-Lux 5 and his ancient Digilux 2 - the former works fine on A, the latter produces the same problems as with the M9. I usually am fine working on A or M since I normally use the 24D as a filler flash but even that doesn’t work with the M9 under these circumstances. Ideas? Thanks very much raxnitz
