Showing results for tags 'retractable_lens'.
Found 1 result
  1. Hi, recently I had designed and built by 3D printing a longer Endcap for retractible lenses. Basically it has an internal depth of 23mm, which i think will fit most of the M mount retractible lenses. I designed this Endcap for my 50mm Elmar F2.8 lens. It is better to use a good 3D printer. I printed this Endcap using my Craftbot Plus printer at " 0.100mm " layer height, with 15% infill. I printed these Endcaps on Glass Bed with Dimafix 3D printer glue. The result is mirror smooth bottom. You can use PLA or PETG. This is a very clean design. There is no oozing to be cut except the last one when the nozzle started to go into Home position. You can use any colors you want. I did not take a picture of the Endcaps today but i will add that to the Dropbox download folder. In this folder you can find a stp file and a stl file suitable for 3D printing. You can revise the design by loading the stp file. A computer rendering is included. Tomorrow evening I will put actual pictures into this downloadable folder. This is the link: https://www.dropbox.com/sh/qsjcj2srlp3moea/AAD6QWKuZBCtYeihflJ3ZzIoa?dl=0
Γ—
Γ—
