Showing results for tags 'q2 leica'.
I purchased a Q2 Reporter just under a year ago and have used it gently. I thought the Kevlar would make this camera a workhorse (something implied by the name) and endure even normal use without too much blemish. I’ve noticed that where the Kevlar meets some of the metal edges, especially in areas of wear (but not always) a few of the Kevlar threads have begun to fray. Is this normal, an underlying flaw in manufacturing, or poor design? I hesitate to send it to Leica in NJ as I’ll lose use of my camera for at least a month. Thoughts?
- 89 replies
- q2 leica
- quality control
(and 1 more)
Tagged with:
Does anyone know of a way to connect the Q2 to a laptop via wifi? It seems like a big oversight not to be able to transfer photos from my Q2 to my phone but not my machine. I work in Lightroom for post and would love to save time and steps. Thanks all in advance.
Is it possible to update the firmware on an Ipad Pro with a Lightning SD Camera Card reader attached?
Hallo Community, bin hier neu in der Community, bin neu mit der Leica, aber nicht neu in der Fotografie. Mein Steckenpferd sind virtuelle Panoramen, aus denen sich sehr schöne großformatige Bilder extrahieren lassen. Bei der Panoramafotografie muss man alle Automatik abstellen. So auch den Autofokus. Nun habe ich gedacht, dass ich mit der App die Kamera (Leica Q2) auslösen kann. Das kann ich zwar, aber nur mit Autofokus. So funktioniert das aber bei den Panos nicht. Ich habe mir nun eine mechanische Hilfe gebaut. Naja... Hat Jemand eine Idee, wie ich die Kamera fernauslösen kann, ohne Autofokus. Vorab schon mal vielen Dank, Ronald
- 6 replies
- 3
- panorama
- panoramafotografie
(and 2 more)
Tagged with:
Hi, I wonder if anyone has had a similar experience and/or suggestions on programming the thumb wheel button. When I first got the camera I had set the button for ISO and it was fine. However now it is no longer set to ISO instead it shows a little icon that looks like a magnifying glass/a circle enclosing ‘x3’, SET and a little square that moves with the direction buttons. Pressing and holding the Thumb Wheel Button does not bring up the available options to allow me to set to ISO. I have reset to the factory settings. No luck. Hoping someone can assist. Thanks
- 26 replies
- q2 leica
- 3.1 firmware
(and 1 more)
Tagged with:
