Showing results for tags 'nikkor 5cm'.
Found 1 result
  1. Hey guys, I'm currently setting up a Leica Screw Mount kit. I will be buying a CLA'd Leica iii with a new splitbeam mirror. The whole kit is planned to be used for a gap year in New Zealand and therefore it needs to be small but still affordable because I'm still a student. Now I can't decide between a probably uncoated but CLA'd Ltm 5cm Elmar f/3,5 and a Nikkor 5cm f/2. The Elmar is incredible small which is amazing for travalling while still having a good quality as a like. And it fits in the ever ready case. BUT I really like using filters and it is very hard to use them on the Elmar because it needs those special A36 filters and I need to put them off everytime to change the aperture which is still hard without the filter. The latter on the other hand doesn't have the advantage of being able to be pushed inside the body to become very small but it uses normal filters and it isnt hard to set the aperture with it. But it does not fit in the everready bag (or am I wrong?). The question is now which one is better? How about the optical quality, I have no ressources to exactly compare them. Greetings
