Showing results for tags 'm 262'.
Found 2 results
  1. I acquired a slightly used M 262 recently and had a problem of it hanging / freezing at the copyright menu option - only turning it off and back on would clear it. The previous owner did not use the camera all that much and only put less than two thousand shutter clicks on it. He professed no issues and I’m inclined to believe him. When I try to go into the copyright option and populate the fields, as I scroll through to choose letters, they sometime disappear before I can choose and move to the next one. One time (and only one time) other menu items began blinking and doing weird stuff. I did my LUF search and found this thread : https://www.l-camera-forum.com/topic/295791-leica-m-262-hangs-while-scrolling-menu/?tab=comments#comment-3713557 I tried all the methods therein to resolve the issue with no luck. So at this point I’m thinking this is a software / firmware issue and should be easily remedied by Leica NJ at a nominal cost so I packed it up and shipped. They ran the diagnostics and said the error code indicated the need to replace the sensor assembly which most of you know contains more than just the sensor, yes? Adjust / replace printed circuit: $2095 Stunned and bummed (would that be “stummed”?). When I asked if it would stay the same or get progressively worse, the reply was, “Though we can never know for sure, it is extremely likely that the problem can get worse over time if not taken care of.” Is that CYA or what? The upshot is I had the camera returned without the repair and made a fair cash settlement with the seller (while keeping the camera). I will continue to use until its function is intolerable. Has anyone else experienced anything like this with their M 262?
