Showing results for tags 'lenses on TL'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. Just curious, has anyone had experience using Voigtlander lenses on the T/TL? (I see that Louis uses a Nikkor 50mm 1.4, which looks excellent. And, Rick P has used the Zeiss Sonnar 50 1.5 with terrific results. I recently started using a Zeiss Planar 50 2.0, which has been quite nice, but was wondering about some faster lenses, as well, thinking that if I were to later acquire the SL 601 they'd serve dual purposes). Specifically, I was considering the Voigtlanders 35mm 1.2 and the 50mm 1.5. Thank you for your thoughts. Rob
