Showing results for tags 'leica s2p'.
Hi! Friends, who has repaired his "S2-P" with serious problems in the service in Germany ? Tell me, what was the price of repair? As far as I know my problem can not be solved by multiple battery charging or leaving the camera without battery for many days. My problem is 99% on the motherboard, which will most likely be replaced completely at the service. I have asked Leica several times this question of the approximate cost to replace the motherboard, but they won't tell me an approximate price. It's hard for me to send them the camera now, but I might be able to do so if I know the approximate cost of the most expensive camera repair (replacing the entire motherboard). Do you think it will be more than 1000 euros, right? If it's more expensive, I might be better off selling the camera for parts. PS The camera stopped working completely, two screens and all controls are completely disabled. However, the shutter button, exposure metering in the viewfinder and even autofocus works, but it doesn't record photos to the memory card. A warning signal flashes in the lower left corner of the viewfinder. The battery trick doesn't help, also attaching the grip (battery pack) doesn't help. Other memory cards, batteries, lenses do not help. The camera has not been exposed to rain. Careful use. A familiar repairman says that there is probably no voltage on the motherboard, that Leica will probably replace the entire motherboard. Thank you all for any possible answers.
