Showing results for tags 'leica m issues'.
Found 1 result
  1. Hi problem could have existed since long but I have just discovered it. Please test yours and let me know if such a problem is common. problem can be regenerated (not always) if you do the following: 1- make sure the camera is off first. Switch it on and directly go to menu. 2- scroll over items slowly downward (allow 2sec between each scroll) 3- camera will probably hang on last item i have noticed if you scroll quick the problem will not arrise. check it out here: https://www.dropbox.com/s/ds1p1u7zbp37wso/IMG_2404.TRIM.MOV?dl=0 woukd appreciate your feedback. thanks
Γ—
Γ—
