Showing results for tags 'grounding issues'.
Found 1 result
  1. OK. I am starting from that point where we all start: total ignorance. I receive my M8.2 today when FedEx delivers the little honey. I would not normally run an eBay camera by a repair facility to check it but this is special. And the seller has a 30 return window so I want a skilled tech to 1) look it over and evaluate its condition and, 2) do a CLA if needed. I will bring it up with the new lens so that the tech can check how well the lens gets along with the rangefinder. I have read on this board and in this sub-forum that two esteemed Leica techs will not open an M8/M8.2 because of "grounding issues." I have asked Wetzlar and finally Leica NJ about this. They have danced all around this and are as good at equivocation as any politician or time-share salesman. The best I could get out of them was that taking the camera to a non-Leica facility may void my warranty. They have not said that any other tech is unable to inspect, evaluate or repair the M8/M8.2. So I am going to be a guinea pig on this. I will take some pics when the camera arrives, of course, just to make sure it works. Tomorrow I will drive up to PDX and drop it off with a repair facility I have had do work in the past. They did the job right in the past on a Pentax digital. I will see what happens. I will know it worked before I brought it up. I will have the digital proof. I will also see what these fellows can do. And the tech left me a message to the effect that the M9 was pretty much an M8/M8.2 inside but with a bigger sensor. So we know he has opened up a few of them. As they used to say on TV, "Tape at Eleven."
Γ—
Γ—
