Showing results for tags 'cl camera'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 2 results
  1. I have been using an only M lens I have left: a Summilux-M 1:1.4/35 ASPH (11663) with my CL body, I now have no more Leica M bodies, which I use to shoot slide films only. What do you think: should I replace the M lens with a: “Summilux-TL 35 f/1.4 ASPH.”? Would this 35f1.4-TL lens much more suited for the CL camera body than the 35f1.4-M lens + “Leica M-Adapter L“ Now the only TL lens I have is the 55-135 zoom.
  2. Good day! Just received a gift of "Leica Summicron-T 23mm f/2 ASPH Lens", not familiar with it yet... but seeing while it's lens hood can be locked in firmly on the forward way, however can NOT be locked, or fit tight on the reverse way... Is it by design? Can this lens hood fit by not to move loosely on the reverse way, or it is not designed for reverse fit/lock on the lens? In a second question, this lens-hook is big compared to the lens (23mm/f2), how many of you do use the hood on this lens? Or you mostly use the lens without this bulky hood?
