Showing results for tags 'adobe lightroom 5.2'.
I am having issues with the WB value on M9-P, or rather the value that Lightroom brings the image in at. I have an M9-P with firmware v 1.196. I shoot at 6000k, but when I import the image (DNG) into Adobe Lightroom 5.2 the WB setting gets altered to 4820k. I raise or lower the WB value and although there is no linear correlation between the value set on the camera and the value set on the imported image, the value assigned to the image in Lightroom is still markedly different from the value that the image has been shot at. I went into Leica Mayfair yesterday and tried the following steps to isolate the cause of the problem: 1. Importing the same image into another copy of Lightroom and it produces similar results although not actually reaching the same WB value as my installation of Lightroom did. Both versions were identical (5.2), and they are vanilla installations with no import filters applied. 2. I have tried shooting at 6000k on an M9 body (provided by Leica UK) with firmware 1.196 and when importing the image it changed the value to 5200k 3. I then tried shooting at 6000k on an M-240 body and it imported at 5800k (closer but still not 6000k). The results are inconclusive - is the problem in the camera (Is there a colour calibration file/setting embedded inside the camera that needs changing/updating? Is the camera writing the full metadata settings to the DNG file?) or is Adobe Lightroom 5.2 not able to import/interpret the metadata correctly and is therefore converting at a different value? Has anyone else experienced the same problem? It is hugely frustrating and I'm struggling to know where to turn next. Although they were helpful and we had a long discussion about this problem Leica Mayfair weren't able to advise on next steps. I have the images from yesterday's experiments. I would like to get in contact with Leica in Germany directly but can't seem to find an email address. Thanks in advance.
- 14 replies
- adobe lightroom 5.2
- m9-p
(and 1 more)
Tagged with:
