Showing results for tags 'SF60 SFC1 Commander'.
Found 1 result
  1. My new SFC1 successfully paired with the SF60 flash. It fires when I press the test button. The flash itself fires on the SL's hot shoe. But when the SFC1 commander is placed in the hot shoe (same settings that fire the flash in the camera's hot shoe) nothing happens. Pressing the test button on the SFC1 triggers the flash, but the SL does not trigger the SFC1. (Shutter speed is was set at 80, well below sync maximum). The focus light on the SFC1 does come on when the shutter is pressed, so I know that the SL is communicating with the SFC1, but the flash doesn't fire. Pairing works and the two devices do communicate and the SL does "see" the commander. And the flash works fine on camera with exactly the same settings. I'm not sure what to do. Anyone have any suggestions? The manuals offer no clue.
Γ—
Γ—
