Showing results for tags 'CF card'.
  • Forenumzug
    • Systemkamera Forum
    • Fuji X Forum (deutsch)
    • Fuji X Forum (English)
    • SAD Temp
    • CER Temp
Found 1 result
  1. Hello, Took my Leica S2 out in London yesterday to see how it performed out of the studio. Took a total of about 50 shots in groups of a dozen or so in 3 locations. Apon my return I discovered that instead of my usual CF AND SD cards I only had the SD card in the camera. Strangely the S2 only saved 8 images (all DNG) to the SD. A single image from the first location. 7 from the second and none at all from the last location. This has never happened before. The battery was fully charged and didn't require changing during the day. The SD card has plenty of space on it. BUT the S2 was set to save in parallel and I've never not had both CF and SD in the camera together AND The camera was set to save DNG only. I'm trying to reproduce the same issue now. Seems that there's maybe an issue with having the camera set to parallel saving when DNG only is selected and there's only an SD card present. Can anyone confirm that for me? Or could this be something more serious? Cheers, Freggio.
