Showing results for tags 'Beseler 23C'.
Found 1 result
  1. Just want to share my experience which I made with a nearly mint Beseler 23C enlarger which I got from a friend of mine for free (in fact it is now my 4th enlarger after getting a 45M, 45MXT, and a 67S II). After having set up my existing enlargers for large format (4x5") and small format negatives printing, I planned to use the 23C for medium format size negatives (6x7 cm) since I also had a Schneider-Kreuznach 80/5.6 enlarger lens. What I was missing is the fitting negative holder for 6x7 cm - I checked online and found a few horrendously expensive used negative holders (the new ones from Beseler were even more expensive). I checked in my clutter box where I kept other scavenged darkroom material, and I found an Omega-enlarger based 6x7 cm negative holder. Glad I didn't buy any of the overpriced Beseler ones - because actually the Omega one fits in portrait mode nicely into the 23C enlarger. Of course there is a little gap between closed upper bellow unit and the holder, but I found it is not an issue at all (no light leaks out to an extent that it would endanger the printing process during exposure). I didn't find it described online anywhere that Omega negative holders can be used in certain Beseler enlargers! The Schneider-Kreuznach 80/5.8 lens also handles the 6x7 cm negative size well with sharp corners when stopped down a bit (I normally use my enlarger lenses at f/11). Didn't find this information mentioned anywhere either - only posts online about the Nikkor 80/5.6 enlarger lens which is able to handle 6x7 cm negative size, too. Does anybody else made similar experiences and used parts of different enlarger types on another to make things work? Or using an enlarger lens less known or supposedly not to work well with a specific negative size but it still works okay? Please share some low cost - big gain experiences!
