Showing results for tags '50mm summicron-r'.
Hello fellow Leica enthusiasts, Caver and R6 user from Canada here. Below is my caving/spelunking camera of choice. Cleans off fine every time and has survived numerous falls, splashes, bumps, etc. without visible damage. More dent resistant than some of the other brass cameras I’ve seen out there. The prism housing is very rigid and well sealed. Everything else not so much but not much has gotten into the base plate of the camera and there is enough room to accommodate a custom seal. The flash is a Metz 54mz4. For my first few trips I mainly just bounced off of different surfaces at various angles and EV compensations on TTL mode. This worked well for a good number of photos and situations. It also kept my camera compact when I’m bouldering or traversing through tight tunnels. However there are some inherent problems with that so nowadays I use a soft box and another wireless flash concurrently which works way better. As for lenses I only have the 50mm Summicron-r V2 and the 28mm Elmarit-r V1 which I use when I'm in the cave itself. Definitely a pain in the ass to swap lenses and it's the main reason why I want to get the Leica r 35-70 f4 when I have the money or if I find a good deal (I'm a broke student and labourer). Still many rolls left to develop and scan with that new set up though but link below if you want to take a look at some older photos. https://analoguefran.com/work/uvcc This quite snapshot of the camera was taken after a trip (some of the mud dried and fell off on the return trip): __________________________ https://www.instagram.com/analoguefran/
