Pimp your M9
geesbert
I know it's a bit sad, but I really do have caring feelings for my M9. I even started to pimp it, something which I wouldn't even start to think about doing to my other cameras...
1.) It's all black, 'M9' removed with a toothstick, black dot.
2.) I removed the shutter button, dissassembled it and polished all parts, now it's much smoother. I already had done that for my M8, I just transfered the button to the M9. See the brassing? I like that!
3.) the camera strap is a silky soft old nylon strap from the camera shop's junk display, cut to perfect length, equipped with Leica buckles, secured by tiny cable ties to get the overhang as short as possible, that actually looks neater than it sounds.
4.) my 50mm pre-asph lux got a summicron tab, which makes focussing even much better.
plan for the future:
maybe recover it, the genuine cover looks cheap, I have a few samples of cameraleather here, but haven't decided yet.
  • Replies 80
  • Created
  • Last Reply
you have to get the special wrench to get the button assembly out. you get that here:
Flexi Clamps Verfgbar von Micro-Tools Europe
the shutter button consists of three parts held together by a tiny screw. undo that and the silver stud comes loose. I polished that with a nail buffer to a perfect shine, I did that while watching a DVD, halveway throught the film I was done.
get it all together again, screw it in and voilà: smooth as butter!
I just removed the white paint with a tooth stick. The black dot is from DAG, easy to exchange.
I really hope the black paint gets a bit duller with time. I much prefered black chrome.
Hi,
can you get me the DAG info so that I can order the black dot?
Thanks
Daniel
yes, but there is also the triangular hole for the RF adjustment. no chance to leave that open.
Wish I could find a thin but nicely made metal disc in Steel Gray, remove the red dot, and install the new one in it's place...
I recall there is a pewter disc with black Leica but Leica will not release them readily as a spare part so they are hard to get - that would be my replacement choice.
I removed my red dot by pressing down with my thumb on to the dot and letting the body heat transfer over & then rotate side to side until the glue bond loosens. It takes a while but was effective for me and no sharp instruments needed.
