Solar Charger for M8 mini charger
Ever since I unpacked the M8 and found the charger had a 12v plug I have wanted to charge using a solar battery of sorts..
I played with the carabiner with a solar panel style gizmos from solio etc... those proved a bit to lightweight for the job.. some could start the charge but nobody could finish the job.
So I talked with a factory I work with in china and got them to modify a laptop strength charger for me, adding a 12v out and a USB port. after all what is a good day without a few tunes from the iPod.
This week I received a box with 3 copies of prototype number 1. it works just as hoped, the battery charges in a full day of California sun. and it is able to deliver a full charge to the leica battery. actually I am pretty sure it will do several charges, but did not have a bunch of flat batteries to toss at it yet.
The battery is 400g 2700mAh a bit lightweight for a laptop, but very portable, and it will put a charge on my netbook just fine. The solar panel 37x26cm 9v 0.6
Great work!
Living in Spain, more sunny than the typical european region, it would be great to use it.
The unit with a set of plugs for the Leica Charger (or any other manufacturer), the Ipod and the Notebook..... would be a great success here.
