veraikon Posted May 19, 2009 Share #1 Posted May 19, 2009 Advertisement (gone after registration) Nur als Querinfo: die japanische Fotozeitschrift AshaiCamera Ausgabe Juni 2009 berichtet von einem Nokton 50 /1.1 das anlässlich des Jahrestages der VC Messsucher Bessa (1999-2009 ?) als Sondermodell (?)herauskommen soll. Interessant wäre der ganze Artikel (falls also ein OM in Japan (z.B. maddoc) in die Printausgabe schauen könnte ????????????????????????????? 2009?6?? guugle Übersetzung Bessa 10th anniversary commemoration 2nd feature! Nokton 50 millimeter F1.1 appearance Standard super large aperture “F1 class” 4 these games! Google Translate Link to post Share on other sites More sharing options...
Advertisement Posted May 19, 2009 Posted May 19, 2009 Hi veraikon, Take a look here Über den Tellerrand: VC Nokton 50 /1.1 in Sicht ? . I'm sure you'll find what you were looking for!
veraikon Posted May 19, 2009 Author Share #2 Posted May 19, 2009 So im RFF wird man fündig. Tom A hat schon getestet Indeed, there is a 50mm f1.1 from Cosina. I did shoot with it in March when we were in japan. Of course, i had to keep quiet about it, which is not easy! It is a very sweet lens, slightly smaller than an older style Noctilux, 58mm filter thread. Weight seemed to be similar, or slightly lighter. The prototype looked a bit like a Nokton 50f1.5 on steroids. Similar knurling on the focus and it "sat" well in the hand when on the camera. There were two versions of the hood. One was a smallish, thread mount one, slightly flared (minimum intrusion into the finder of the M2 and ZM) and the other one was a larger diameter one with a clamp-on screw. Image quality was very good. For obvious reasons I shot most everything at f1.1 or there-abouts. The corner fall off is less than on the Noctilux f1.0- looks to be around 1,0-1.5 stops. Less of peering through a tunnel as the Noctilux tended to create. Sharpness at f1.1 is very good - I did not do "resolution" tests - but looking at the negatives - I would have no problem blowing them up to 11x14 or 16x20 without having the lens being the limiting factor. ..... The price seems to be set at around $1100 - but that might depend on exchange rate too. I will post some shots from it later today. .... http://www.rangefinderforum.com/forums/showpost.php?p=1056984&postcount=64 honi soit qui mal y pense. Off topic : Ich halte die PR Maschine die da anläuft schon interessant . Leica könnte sich ne dicke Scheibe abschneiden Link to post Share on other sites More sharing options...
Franz S. Borgerding Posted May 19, 2009 Share #3 Posted May 19, 2009 Autsch. Für Solms. Die Scherbe scheint ja sogar tauglich.(wie auch das 21er, 15er, 50er qua eigener Erfahrung). Beste Grüße, Franz Link to post Share on other sites More sharing options...
Guest Colt Seavers Posted May 19, 2009 Share #4 Posted May 19, 2009 Wenn die Kopie BESSA als das Original wird, nennt man das nicht mehr "Plagiat", sondern "vorgeführt werden" Zum Glück erwägt man nur eine Sonderserie, um Leica nicht allzu massiv zu schaden. Richtige Konkurrenz ist das Ding aber eh nicht - für eine Vitrinen-Queen viel zu günstig! Link to post Share on other sites More sharing options...
Guest maddoc2003jp Posted May 20, 2009 Share #5 Posted May 20, 2009 Nur als Querinfo: die japanische Fotozeitschrift AshaiCamera Ausgabe Juni 2009berichtet von einem Nokton 50 /1.1 das anlässlich des Jahrestages der VC Messsucher Bessa (1999-2009 ?) als Sondermodell (?)herauskommen soll. Interessant wäre der ganze Artikel (falls also ein OM in Japan (z.B. maddoc) in die Printausgabe schauen könnte ????????????????????????????? 2009?6?? guugle Übersetzung Google Translate Ich werde versuchen, die Printausgabe der Asahi trotzdem mal zu bekommen, sollte seit heute im Handel sein. Ich habe mir Tom's Bilder bei flickr noch nicht angeschaut, lediglich ein paar Kommentare im RFF gelesen. Danach sieht es so aus, als ob das bokeh eher dem CV 40/1.4 als dem CV 35/1.2 nahe kommt. Ich bin jetzt doch mal sehr gespannt, wie sich das neue Leica 50/0.95 ASPH in der Praxis zeigen wird Link to post Share on other sites More sharing options...
cron Posted May 20, 2009 Share #6 Posted May 20, 2009 dann darf ich folgende Bilder hier anschließen: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/85406-%C3%BCber-den-tellerrand-vc-nokton-50-11-in-sicht/?do=findComment&comment=905209'>More sharing options...
Guest maddoc2003jp Posted May 20, 2009 Share #7 Posted May 20, 2009 Advertisement (gone after registration) Der optische Aufbau sieht dem des Noctilux 50/1:1.0 verblüffend ähnlich, lediglich die Dicke der beiden hintersten Elemente scheint unterschiedlich. So spannend das neue Nokton 50/1:1.1 auch sein mag, ich fand die ersten Beispielfotos, aufgenommen mit einem Produktions-Modell des neuen Noctilux 50/0.95 ASPH und einer M8 (oder war es die M8.2 ?) interessanter. Link to post Share on other sites More sharing options...
veraikon Posted May 20, 2009 Author Share #8 Posted May 20, 2009 Das Nokton 1.1 ist jetzt auf der japanischen Voigtländerseite aufgetaucht ƒmƒNƒgƒ“50mm F1.1 Tante guugel translatiert wie folgt: Übersetzung: Japanisch » Englisch Classic flavors of the lens, the latest technology to蘇RA. 10 BESSA series to commemorate the anniversary of the founding Koscina 50 ultra-high-speed lens is designed as a culmination of the year. ● large aperture of dismay Open-aperture F value of 1.1 is large, even extremely low light conditions, "natural light" can be taken alone. The lens is ideal for shooting portraits based on taste and beautiful defocusing shallow depth of field at open aperture. Lens design for ultimate ● Describe performance in pursuit of the town to launch ultra-high refractive index glass. Open the aperture to ensure sufficient amount of light from the surroundings. F1.1 large aperture and a filter diameter of φ58, Weight 428g (not including food) to provide a compact. ● ability to express various The aperture opening is set off with creating a three-dimensional motif combined with mild dementia focus is straightforward. In addition to the sharp delineation絞RI込ME, one can begin to guide the expression in a variety of photo lenses. Focal length / 50mm Aperture ratio / 1:1 Minimum Aperture / F16 This lens / 6 of 7 photos Angle / 45.9 ° Number of diaphragm blades / 10 sheets Minimum focusing distance / 1m Integration range in range / ∞ ~ 1m Maximum total length × diameter / φ69.6 × 57.2mm Filter size / φ58 Weight / 428g Mount / VM Mount Lens hood / hood included standard Zeiss Ikon, Leica Stock for optional hood Retail Price (without tax) Lens body ¥ 125,000 Link to post Share on other sites More sharing options...
wizard Posted May 20, 2009 Share #9 Posted May 20, 2009 Nun wartet mal alle schön ab. Wer hier wen vorführt werden wir erst wissen, wenn das neue Nokton als Serienobjektiv von mehr als nur einem Benutzer getestet worden ist. Ich erinnere mich noch gut an den hype, der um das Nokton 1,4/35 gemacht wurde. Als es dann verfügbar war, waren die Berichte der Benutzer eher enttäuscht, manche haben es gleich wieder zurückgegeben. Insgesamt herrscht heute die Meinung vor, dass das CV 1,4/35 kein großer Wurf ist, ähnliches gilt für das 1,4/40. Andere CV Objektive (ich habe diverse) sind durchaus brauchbar, aber ich habe bis jetzt KEIN EINZIGES gesehen, das einem modernen Leica Objektiv insbesondere hinsichtlich der Randschärfe das Wasser hätte reichen können. Für den Preis der CVs ist das wohl auch nicht zu erwarten, aber deshalb halte man sich ebenso mit der Erwartung zurück, das neue Nokton werde Leica zeigen, wo der Hammer hängt. Wenn Leica eines kann, dann ist es Objektive bauen. Grüße, Andreas Link to post Share on other sites More sharing options...
veraikon Posted May 20, 2009 Author Share #10 Posted May 20, 2009 Nun wartet mal alle schön ab. Wer hier wen vorführt werden wir erst wissen, wenn das neue Nokton als Serienobjektiv von mehr als nur einem Benutzer getestet worden ist. ... Richtig ! Ich war gestern hin und her gerissen ob ich die Info posten sollte. Letztendlich hat die Information gesiegt, da das Nokton 1.1 von allgemeinem Interesse sein dürfte. Die PR Maschine die dahinter steht sehe ich auch sehr kritisch. Das war nicht nur beim 40er zu beobachten. Das Muster ist immer sehr ähnlich Man sollte mit dem jubeln arten und die ersten Serienmodelle und deren Aufnahme[n] abwarten. Nichtsdestotrotz sollte m.M. auch im LuF sachlich darüber informiert werden. Link to post Share on other sites More sharing options...
cron Posted May 20, 2009 Share #11 Posted May 20, 2009 gar sowas von arg und nicht sehenswert wird die Leistung schon nicht sein, siehe Bilder in flickR: Voigtlander Nokton 50mm f1.1 - a set on Flickr Link to post Share on other sites More sharing options...
dokterli Posted May 20, 2009 Share #12 Posted May 20, 2009 Hier auch für 999.--: Lichtstärke extrem: Voigtländer Nokton 1,1/50 mm | photoscala Gruss KHL Link to post Share on other sites More sharing options...
veraikon Posted May 20, 2009 Author Share #13 Posted May 20, 2009 Die deutschen Marktpreise pendeln sich z.Z. (i.d.R.) so 10% unter dem "EVP" ein. Link to post Share on other sites More sharing options...
Holger1 Posted May 20, 2009 Share #14 Posted May 20, 2009 Richtig ! Die PR Maschine die dahinter steht sehe ich auch sehr kritisch.. ... und desshalb haben Sie es auf die Leica-Seite gestellt...toll Link to post Share on other sites More sharing options...
Guest Digiuser Posted May 20, 2009 Share #15 Posted May 20, 2009 ... und desshalb haben Sie es auf die Leica-Seite gestellt...toll Na und, wir sind doch hier nicht bei den Kleinkindern, die wenn sie sich die Augen zuhalten der Meinung sind man könne sie nicht sehen. Die VC und Zeiss Objektive für die Ms sind nun mal Realität. So gut wie die Leica Optiken auch sind, zwischen 999,- und 8000,- Euro - bei praktisch gleichem Anwendungsbereich - sehe ich sehr wohl einen Sinn auch mal auf des VC hinzuweisen. Für ein Achtel des Preises kann man auch ein paar optische Unzulänglichkeiten in Kauf nehmen. Link to post Share on other sites More sharing options...
fth Posted May 20, 2009 Share #16 Posted May 20, 2009 Wenn das Nokton 1.1/50 mm für 1000 Euro optisch auch nur so gut ist wie das alte Leica 1,0/50 mm (bitte an den Preis erinnern!) und dabei mechanisch so gut ist wie das Nokton 1,2/35 mm, dann ist doch alles paletti. Ich erwarte von hochlichtstarken Spezialisten wie dem 1,1/50 mm oder 1,2/35 mm nicht die Randschärfe eines Summicrons. BTW, ich kenne auch vom VC 1,4/40 mm und vom VC 1,4/35 mm begeisterte Anwenderberichte und schöne Aufnahmen, auch wenn ich mein VC 1,5/50 mm dem VC 1,4/40 mm vorziehe, weil ich das 50er für einen Tick besser halte, vor allem aber, weil mir die etwas längere Brennweite und der in der M/ZI vorhandene 50er-Bildrahmen sympathischer ist. Ich bin jedenfalls gespannt auf den VC-Klops. Ich glaube kaum, dass der Leica-Absatz des neuen 0,95/50 ASPH. unter dem Voigtländer 1.1/50 mm leiden wird. Vielleicht schafft es ja der japanische Underdog beim einen oder anderen, die Lust an der bezahlbaren analogen Messsucherfotografie neu zu entfachen. Auch nicht schlecht. Ich finde es toll, dass der durch Voigtländer und Zeiss bereicherte M-Objektivmarkt weiterhin wächst und wächst und wächst. Die Gewinner dieser Entwicklung sind wir, die Kunden/Anwender. Link to post Share on other sites More sharing options...
Guest uwe1 Posted May 20, 2009 Share #17 Posted May 20, 2009 Ich will fair sein: Das neue Nokton ist nicht weniger unsinnig an einer Meßsucherkamera, als das entsprechende Produkt des Mitbewerbers aus dem Land des Appelwois. Link to post Share on other sites More sharing options...
Guest camera Posted May 20, 2009 Share #18 Posted May 20, 2009 Ich will fair sein: Das neue Nokton ist nicht weniger unsinnig an einer Meßsucherkamera, als das entsprechende Produkt des Mitbewerbers aus dem Land des Appelwois. ... und ich dachte immer, Portugal wäre das Land der spritzig moussierenden Vinho Verde und des Portweins ... Link to post Share on other sites More sharing options...
Guest kalokeri Posted May 20, 2009 Share #19 Posted May 20, 2009 ... Die PR Maschine die dahinter steht sehe ich auch sehr kritisch. Das war nicht nur beim 40er zu beobachten. Das Muster ist immer sehr ähnlich ... Nichtsdestotrotz sollte m.M. auch im LuF sachlich darüber informiert werden. Ähnlich oder immer gleich? Tom A. bekommt ein Objektiv, wenn er ganz zufällig Herrn K. besucht. Wenn er genügend Zeit hatte, Bilderchen zu produzieren, streut einer ein Gerücht im RFF, das kurz darauf bestätigt wird. Stunden später gibt es die vorproduzierten Bilderchen auf flickr und ein enthusiastischer Diskurs im RFF stoppt erst, wenn Steven G. dann verkündet, er habe ausgeliefert. Dann beginnt die Phase der Ernüchterung bis zum nächsten Streich ... Thomas Nachtrag: Scheinbar bekommt Cosina Fertigungstoleranzen nicht in den Griff. Deshalb sind Serienstreuungen als Grund für sehr differente Bewertungen der Objektive wahrscheinlich. Manche Exemplare sind nicht nur BILLIG, sondern auch GUT, andere leider nicht. Braucht man also Glück beim Kauf? Link to post Share on other sites More sharing options...
Guest Digiuser Posted May 20, 2009 Share #20 Posted May 20, 2009 ... und ich dachte immer, Portugal wäre das Land der spritzig moussierenden Vinho Verde und des Portweins ... Du befindest Dich aber im falschen Land. Schau lieber mal was Kanada so zu bieten hat..... Link to post Share on other sites More sharing options...
