Knott End ferry quay
stunsworth
x
Steve, what I like here are all the lines, very nicely composed (I agree with Stuart, the photo'd probably be better without the central post). There is a beautiful silence in the photo.
Jonathan
I can see what you are getting at here, Steve, but I personally find the central lamp post a bit unfortunate, as it cuts the image neatly in two.
I am with Andy on this it does indeed segment the image into two...unfortunate... having said that...being digital..you can "walk your pictures" and reframe... until you get the desired result..this is the beauty of digital..you get immediate sensory feedback and can see your "mistake" right away.
So to conclude..the "idea and concept" is sound but not the execution.
Thanks for sharing
Regards, Leicamann
Having noted the above remarks, I do see quite a bit of scope here for further variations. Assuming you have time and opportunity, why not return and experiment? As John Mead says, digital does give you a second chance while you are there. Often we pass over that opportunity.
David
