lburn Posted December 3, 2011 Share #1 Â Posted December 3, 2011 Advertisement (gone after registration) On my Summicron 35mm the lens aperture ring moves past the marked F2 stop position by a very small amount. Looking at the front optic I can see the aperture widen so that the lens is now wide open whereas at the F2 stop setting a fringe of the aperture leaves is visible. What is the practical effect of this? Is the lens at F2 at the marked setting and slightly wider when I go past it? Is this quite common (the lens is a new copy of the current version). lburn Link to post Share on other sites More sharing options...
Advertisement Posted December 3, 2011 Posted December 3, 2011 Hi lburn, Take a look here Real maximum aperture setting. I'm sure you'll find what you were looking for!
digitalpowershot Posted December 3, 2011 Share #2 Â Posted December 3, 2011 Tried it with my Summilux. You can turn it past the f/1,4 by a very very small amount, but it does not stay that way, it jumps right away back to the initial f/1,4 spot.... Link to post Share on other sites More sharing options...
jaapv Posted December 3, 2011 Share #3 Â Posted December 3, 2011 It has been asked before. The consensus is that there is no perceptible result. Link to post Share on other sites More sharing options...
Double Negative Posted December 3, 2011 Share #4 Â Posted December 3, 2011 Just look through the lens or down the front of it against the light. First at f/1,4 and then all the way to "lock" - see if there's any change. More than likely, there won't be. Once the blades are fully retracted (or out of the way) that's it. Link to post Share on other sites More sharing options...
ho_co Posted December 4, 2011 Share #5 Â Posted December 4, 2011 It's normal for some designs. Enjoy it! Link to post Share on other sites More sharing options...
wda Posted December 4, 2011 Share #6 Â Posted December 4, 2011 On my Summicron 35mm the lens aperture ring moves past the marked F2 stop position by a very small amount. Looking at the front optic I can see the aperture widen so that the lens is now wide open whereas at the F2 stop setting a fringe of the aperture leaves is visible. What is the practical effect of this? Is the lens at F2 at the marked setting and slightly wider when I go past it? Is this quite common (the lens is a new copy of the current version).lburn Have you compared results on computer? Link to post Share on other sites More sharing options...
bill Posted December 4, 2011 Share #7 Â Posted December 4, 2011 Advertisement (gone after registration) It's a feature not a fault Stop frettin'... Â Regards, Â Bill Link to post Share on other sites More sharing options...
Guest #12 Posted December 4, 2011 Share #8 Â Posted December 4, 2011 Have you compared results on computer? Â + 1 Link to post Share on other sites More sharing options...
