Washington Posted August 28, 2011 Share #1 Posted August 28, 2011 Advertisement (gone after registration) Are there M male-female bayonet extension tubes anywhere? I’ve never run into such except the short and very expensive … oops, I forgot the #. Link to post Share on other sites More sharing options...
Advertisement Posted August 28, 2011 Posted August 28, 2011 Hi Washington, Take a look here M extension tube question.. I'm sure you'll find what you were looking for!
40mm f/2 Posted August 28, 2011 Share #2 Posted August 28, 2011 There is 16469Y (approximately 12 mm extension) Link to post Share on other sites More sharing options...
k-hawinkler Posted August 28, 2011 Share #3 Posted August 28, 2011 Rip, Here you go OUFRO/16469Y/16469 http://www.l-camera-forum.com/leica-forum/leica-collectors-historica/181223-oufro-16469y-16469-differences.html. If you need to extend quite a bit, use your Nikon extension tubes and put the appropriate adapters at either end. That works well for me. I use inexpensive Fotodiox adapters that are accurate enough for me. Amazon.com: Fotodiox Pro Adatper, Leica Visoflex M Lens to Nikon Camera Mount Adapter for Nikon D1, D2, D3, D3x,D3s, D100, D200, D300, D300s, D700, D40, D40x, D50, D60, D70, D70s, D80, D90, D3000, D3100, D5000, D7000: Camera & Photo Amazon.com: Fotodiox Lens Mount Adapter, Nikon Lens to Leica M Adapter, fits Leica M3 · M2 · M1 · M4 · M5 · CL · M6 · MP · M7 · M8 · M9, Hexar RF · Epson R-D1 · 35mm Bessa · Cosina Voigtländer · Minolta CLE · Rollei 35 RF · Zeiss Ikon: Camera & Photo Just the two adapters stuck together give you an extension tube of 41.00 mm. K-H. Link to post Share on other sites More sharing options...
Dao De Leitz Posted August 28, 2011 Share #4 Posted August 28, 2011 ... 16469Y (approximately 12 mm extension) Hello, the extension of OUFRO/16469 ist 10mm. Greeting Thorsten Link to post Share on other sites More sharing options...
Washington Posted August 28, 2011 Author Share #5 Posted August 28, 2011 Nope need more than the #16469 OUFRO can do. The adapted Nikon tubes sounds good! Thanks!!!! Link to post Share on other sites More sharing options...
k-hawinkler Posted August 28, 2011 Share #6 Posted August 28, 2011 Hello, the extension of OUFRO/16469 ist 10mm. Greeting Thorsten I measure 10.00 mm as well. K-H. Link to post Share on other sites More sharing options...
Robert_M Posted August 28, 2011 Share #7 Posted August 28, 2011 Advertisement (gone after registration) Rip, If you need a 41mm spacer, you can use one of those extra Visoflex housings you have. Use just the main body, lock the mirror up, don't put on a finder. It is not elegant but will work until you find something else. RM Link to post Share on other sites More sharing options...
