Lens hood X2..question.
metalbernd
I can't comment on the 12460 either, but I bought a Kiwi tube and it came with a hood as well. It looks rather Leica-like and is vented as well. It is made well and the threads are very smooth. A great value for under $30 US.
Jeff
Jeff
OK, so where does one find a Kiwi Tube (link, preferably)?
A Google search for the term yielded a lot of, let´s say, ´unexpected´ results......:rolleyes: One has to wonder what´s going on down under.....
This is how I did make this Leica hood 12460 perfect.
When you screw the hood on the Leica, the front is on one line with the lens.
So I found a rubber gasket that is 3mm thick, I put this ring around the screw mount of the camera, against the camera. Than screw the hood on against the rubber ring en turn a little bit more.
So now there is 3mm overlapping between the hood and the lens.
See my crappy photo.
It is a rubber ring from the plumber store, just search for rubber gaskets.
Don't buy the oily or greased one, just the dry black rubber.
I take a little bit smaller so it stretch out when you put it on.
You can buy them with several sizes, that depend how thick you filter is.
http://www.vanwalraven.com/img/products/295924pl.jpg
But not to thick, make sure that the hood stay firm and lock on the screw-tread.
  • 2 weeks later...
12460 Leica hood + Smiths automotive rubber gasket is how I fitted mine about 10 months ago too and posted the details previously to this forum. Works a treat and gives a great cupped hand position for steadying shots.
However there is no filter thread on a 12460 unlike the Kiwi tube, so it depends on what you want the hood for whether the 12460 is useful to you. In my case I have no need to fit a filter since the lens quality is so high any additional glass is likely to degrade IQ. But if you're looking for a hood to screw in close up magnification lens, then the 12460 isn't going to help you.
