X 1 and spotting scope
Bill Allsopp
Does anyone have experience of using an X1 with a spotting scope?
If so any and all information gratefully received and example images would be nice too.
Particularly;
What sort of effective focal length does one get?
What are the effective exposure settings of this set up?
Many thanks
x
I use the X1 with a Leica® APO Televid 82 Angled Spotting Scope.
Not being big into photography (just yet). I just make sure I have the Aperture set to f2.8.
I have experimented with ISO settings especially in low light conditions in an attempt to stop the graininess. But with birds very rarely truly still, I end up with blur at the lower ISO settings. So I am happy to go with Auto ISO, but cap it at 800.
All of the bird photos in the following stream have been digiscoped with the above set up.
photos
Overall I am very happy with the results. I didn't expect to be able to capture moving birds. But when a bird is still long enough. I often get better results than others with 10K worth of kit.
photos
Many thanks, very useful.
  • 4 weeks later...
Hi
Just some example image with Leica X1 and spotting scope.
First photo: Leica X1 without the scope. Distance to the ship is 5000 mtr (5 km).
Next photo from the same spot with Leica X1 and Nikon Fieldscope.
The ship is 230 mtr long and 38 mtr wide.
100% crop.
5000 mtr is a long distance and I think this is not bad longrange quality.
btw. it is in a Norwegian fjord :rolleyes:
Thanks!
  • 3 weeks later...
I wish to use my X1 to digiscope with my APO Televid 62 for which I have (a) Leica 16x- 48x eyepiece & (B) Leica 32x eyepiece. I have not seen a specific Leica adaptor listed - probably because the Televid 62 was discontinued by the time the X1 was available. Is there a decent generic digiscope adaptor available?
Best wishes
dunk
Hello
Can you measure your eyepiece diameter (in mm)?
Using a caliper the diameters are:
T62 32x eyepiece: 4cm diameter rubber eyecup; 3.7cm diameter across the barrel of the eyepiece behind the eyecup
T62 16x-48x zoom eyepiece: 4.1cm at front of the rubber eyecup (ie where te eye looks) but 4.2cm at rear of eyecup ie the rubber eyecup tapers slightly towards the front; and 4.1cm across the barrel of eyepiece behind the eyecup
Thank you
dunk
From the X1 digiscoping adapter manual:
"Compatible eyepieces:
The LEICA X1 Digiscoping Adapter is designed for the Leica
APO Televid 65/82 models, which have their own eyepieces.
It cannot be used with the eyepieces on the earlier APO Televid /
Televid 62 and 77 models."
All right. (a) the lens (glass) on the X1 is 20mm, the lens on your eyepiece must be 20mm or more.
I can't use my 16mm diameter eyepiece (to small), My 31mm diameter eyepiece works perfect.
(B) if you want to use the Leica X1 digiscoping adapter (part no. 42331L) you need som kind of spacer or a plastic tube or something between your 40mm dia,eyepiece and 58mm inner dia, X1 adapter. Thats easy to fix.
Conclusion: you can use the Leica X1 digiscoping adapter if your eyepiece (glass) is + 20mm and you find something to center your eyepiece in the X1 digi. adapter.
You can also use Vortex Universal Digiscoping Adapter model: 28mm-45mm diameter. I ordered mine from Adorama, but it is more tricky to use.
I don't know much about Televid, but I think there is a 32x wide angle eyepiece for the 62?
I can't answer your specifics on the X1, or the spotting scope, but as astro-photography is also a passion of mine I might be able to suggest something.
Deal with Baader Planetarium, in Germany, they are very e mail friendly and helpful.
Startseite Baader-Planetarium GmbH - Mammendorf
I know they certainly off adaption systems to accommodate most of the cameras out there today, as well as many of the eyepiece sections. I'll be surprised if they cannot sort something out.
Gary
[ATTACH]308202[/ATTACH]
Sorry, I misunderstood your question about eyepiece diameter - I assumed you meant the eyecups for the purposes of attaching an adaptor. The actual glass eyepieces on the 32x and the 16-48x zoom are both 18mm diameter so I guess they are not compatible with the Leica X1 digiscope adaptor.
dunk
  • 4 weeks later...
Sorry for the late response.
Here is my setup with Leica X1 and Nikon ED 82 Fieldscope.
Leica M9P / 50mm Summilux ASPH @ 1.4
photos
good photos! did you crop the images much?
