Alberti Posted October 5, 2012 Share #1 Posted October 5, 2012 Advertisement (gone after registration) There is now support in the new M for R-lenses - through an appropriate adapter. I have an excellent 180 mm Telyt that is collecting dust. So - - how about supporting vintage Visoflex lenses? What I would like: 1) a visoflex adapter (without the mirror of course, just a tube) 2) capability to select the Visoflex lenses in fact there was one adapter like this with a shoe for attaching a sniper viewer. There are only a view once in a while on the market, very expensive . . :-(( Such a simple visoflex adapter can be second source of course. I would buy from a far-east source without a pain in the heart... Link to post Share on other sites More sharing options...
Advertisement Posted October 5, 2012 Posted October 5, 2012 Hi Alberti, Take a look here M and Visoflex lenses. I'm sure you'll find what you were looking for!
Lindolfi Posted October 5, 2012 Share #2 Posted October 5, 2012 There is a visoflex lens to EOS mount adapter I bought from CameraQuest. If we combine that with an EOS to M mount adapter, that may already exist or will be made in the near future with the appearance of the M, you have a double solution: mounting visoflex lenses to the M without the mirror box of the old visoflex and being able to put EOS lenses on the M. Presumably a similar solution could be found with Nikon mount.... Link to post Share on other sites More sharing options...
UliWer Posted October 5, 2012 Share #3 Posted October 5, 2012 You may find some ideas how to adapt the Viso-Lenses without an Viso-body here: http://www.l-camera-forum.com/leica-forum/leica-collectors-historica/257005-flange-flange-distance-visoflex-body.html#post2196544 Though as all those TXBOOs etc. are rare and are only made for some lenses, to use a Viso III which enables you to fix the mirror would be the most practical way for using the Viso lenses. You than can use the Viso-viewfinder in addition to the display, or even the so called "Electronic-Visoflex", if you don't put on the optical viewfinder. I guess (though I am not sure, as of course I havn't tried) that the optical viewfinder for the Viso will normally be the best solution. Link to post Share on other sites More sharing options...
Alberti Posted October 5, 2012 Author Share #4 Posted October 5, 2012 I see many have shed their ideas already. It is indeed a similar unit as TXBOO that I had in mind, but more basic (no shoe needed). As I have a Visoflex II, I think a new TXBOO tube would make a better option - otherwise I would have to blacken the viewer ground glass, i.e. tape it off, and that is esthetically not very pleasing (and heavy). With a new eVisoflex (EVF-2) viewer on the market for the M, I expect mirrored V-III's to be offered now for a low amount, if there is a 41mm adapter 'ring' (or tube) available to use for those users. Basically, I like the configuration/options of the new M. Link to post Share on other sites More sharing options...
