fishblimp Posted November 22, 2009 Share #1  Posted November 22, 2009 Advertisement (gone after registration) Last night I took about 10 to 15 shots and even reviewed them on my LCD screen. Today when I went to download them to my computer, the image files weren't there.  I'm guessing one of two things happened: 1. The images I saw on the LCD were only saved into the built-in camera memory and NOT onto the card.  or  2. They're on the SD card but somehow hidden? I know that there's a program that allows you to find hidden (or previously deleted) images/files from flash media cards. I forget the name of it at the moment, however. Link to post Share on other sites More sharing options...
Advertisement Posted November 22, 2009 Posted November 22, 2009 Hi fishblimp, Take a look here images apparently not recorded to SD card?. I'm sure you'll find what you were looking for!
cgthanos Posted November 22, 2009 Share #2 Â Posted November 22, 2009 Same exact thing happened to me yesterday. In my case, I was able to get the images by switching the camera's USB mode to mass storage, then manually transferring the images. 2 out of those 10 were unable to load due to a file error, but luckily I didn't need those. Hopefully this will work for you. Â I love this camera, but I have to admit that I'm getting a little annoyed with these kinds of issues (timer release exposure bracketing is also freezing up the camera). Good luck! Link to post Share on other sites More sharing options...
fishblimp Posted November 22, 2009 Author Share #3 Â Posted November 22, 2009 thanks! yeah, my only issue has been with file-related things like this (and/or writing and/or SD card type of issues). Â So what do you mean switch to mass storage...where is that setting? I'm on a Mac. Link to post Share on other sites More sharing options...
jaapv Posted November 22, 2009 Share #4 Â Posted November 22, 2009 Have a look at rescue pro. There is no built-in camera memory -just a buffer and it holds about 7 to 8 images. So if you had 15 it must be an SD card error. Or was it write-protected? Link to post Share on other sites More sharing options...
Guest WPalank Posted November 22, 2009 Share #5 Â Posted November 22, 2009 Fishblimp, Â Did you try to download directly form the camera or did you use a card reader? Link to post Share on other sites More sharing options...
fishblimp Posted November 22, 2009 Author Share #6 Â Posted November 22, 2009 From a card reader. Also, I put the card back in camera but images weren't viewable there either though older images were. Link to post Share on other sites More sharing options...
Guest WPalank Posted November 22, 2009 Share #7 Â Posted November 22, 2009 Advertisement (gone after registration) From a card reader. Also, I put the card back in camera but images weren't viewable there either though older images were. Â OK, Â Are you sure you are using a SD card and not a SDHC card? The SD card reader will not work for SDHC cards. Â I thought I had ordered a SD card and was sent an SDHC card instead. I found that none of my card readers would upload and that's how I diagnosed the problem. Â Then I went to a well known camera store and asked for a SDHC card reader and the guy told me they were all the same. He was wrong and I went somewhere else! Link to post Share on other sites More sharing options...
