| Leica Collectors & Historica This forum is about collecting Leica cameras and lenses. Historica and photographica - whatever the Leica collector wants! |
#1 (permalink) |
Erfahrener Benutzer
Hello,
I just found this filter, complete with box and keeper, as you know Summarit 1.5/50 are E41, this let may thinking of the first Summilux(es) 1.4/50 which are E43 and were first called Summarit(s) note the double engraving E. Leitz N Y SL and GERMANY (the diameter is exactly E43) comments welcome Cheers JC |
#4 (permalink) |
Erfahrener Benutzer
Thanks for sharing, JC, ... even in small accessories one can find rare and unusual items... the engraving is intriguing, and for the diameter... who knows ? One can speculate something about the first batches of Summiluxes or "Summarits 1,4"... with the regular E43 UV filter not yet in production...
I have a XOOYL, with its box, but it's a standard E41, and my E43 UV for Summilux is completely different from the item you post : chrome mount is thinner, and with the standard engraving (and had a different code, of course, 13206 or YMZOO if I remember right) |
#5 (permalink) |
Erfahrener Benutzer
These filters are nice, but for a user they often leave something to be desired. New filters often have much better coating.
Regarding 43mm filters, you need Leica as all other filters I have seen are too thick and one cannot mount the hood with the filter in place. The solution has been to remove the glass from the Leica mount (easy), cut open the rim of a modern filter like B + W MRC, and mount the glass back in the Leica mount. This gives you a "modern" filter but with the classic Leica look. |
#6 (permalink) | |
Erfahrener Benutzer
Quote:
However the filter is an EL NY and could well have been a small run contracted by them for a specific purpose, such as fitting to early Summilux lenses prior to production of the Leitz filters which permit fitting of the hood. It is highly doubtful that EL NY issued filters for a hand-ful of prototype lenses. |
#7 (permalink) | |
Erfahrener Benutzer
Quote:
#8 (permalink) | |
Erfahrener Benutzer
Quote:
#3 is the E43 for Summarit (little steped)and #4 is the E43 for the Summilux. Thanks for the interest. Last edited by jc_braconi : 10/26/07 at 06:35 PM. |
#9 (permalink) |
Erfahrener Benutzer
Actually, between the 1940's, 1950's, 1960's and probably even later, Leitz Wetzlar never made Skylight filters. All Skylight filters I have ever seen came from Leitz New York and were marked as such. Most were in mounts supplied by Wetzlar, which explains the 'Germany' engraving.
Best, Jan |
#11 (permalink) | |
Erfahrener Benutzer
Quote:
Vinay, I would have assumed that a person of your stature and immense knowledge would be aware of the fact that the Summarit 1.5/50mm was also available with the Taylor & Hobson engraving.... Best, Jan ![]() |
#14 (permalink) |
Erfahrener Benutzer
Some very early Summarits had the Taylor #. At the time, whilst the British patent had expired the US Patent had not yet. These and the late Xenons are almost identical, and even harder to differentiate if the clarity of the photo leaves something to be desired as in this case. Aside from the obvious ring marking which is obliterated in this photo, the aperture scale isn't visible either. That, and to add even more confusion I've seen many examples of Frankenstein cobbling-together of these two series. My Xenon and Summarit are more easily distinguished because my (one and only) Summarit is a Canadian. I have a more extensive array of Summicrons, including a Summitar* (early Cron prototype), and Summiluxes. Lenses of lesser repute such as the Summar and Xenon/Summarit occupy less of my interest.
#16 (permalink) |
Erfahrener Benutzer
mmmhhh... I can understand, but anyway I sometime regret to have not a non rectractable Summar... years ago I passed away to buy a nice one for less then 400 Euros... now is hard to find at such a price...
| Thread Tools | |
| Display Modes | |
