russell Posted July 19, 2007 Share #1 Â Posted July 19, 2007 Advertisement (gone after registration) I've been using my Summar on an R-D1 and now on the M8. In order to get the best results you have to use one of these B&W 486 UV/IR filters. Problem is I dont know which filter size and thread pitch that fits onto the Summar. Someone mentioned that it's a 34mm but I wouldnt know for sure... It seems Foto Huppert has a 34mm x 0.5 I could buy.. Does anyknow know? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted July 19, 2007 Posted July 19, 2007 Hi russell, Take a look here Summar: filter thread size and pitch?. I'm sure you'll find what you were looking for!
Philippe D. Posted July 19, 2007 Share #2 Â Posted July 19, 2007 Hi! Summar ... It seems Foto Huppert has a 34mm x 0.5 I could buy.. Does anyknow know? Yes, E34 is the right size.But do you really need an IR filter on your Summar ? Link to post Share on other sites More sharing options...
russell Posted July 19, 2007 Author Share #3 Â Posted July 19, 2007 Yes, for the M8 you do. Otherwise all the trees go reddish. And black clothes also go magenta. So, you kind of need it... Link to post Share on other sites More sharing options...
Philippe D. Posted July 19, 2007 Share #4 Â Posted July 19, 2007 Yes, for the M8 you do. Otherwise all the trees go reddish.You're right, I just give a try, trees leafs goes reddish with this old lens (i usually have mounted on a IIIf). Link to post Share on other sites More sharing options...
luigi bertolotti Posted July 19, 2007 Share #5 Â Posted July 19, 2007 Summar accepts also the well known A36 filter size with clamp screw, superstandard for used on the perennial Elmar... can be found an IRUV of this kind ? Link to post Share on other sites More sharing options...
russell Posted July 20, 2007 Author Share #6 Â Posted July 20, 2007 >can be found an IRUV of this kind? Â No. That's one of the problems. I hope one of the filter makers wakes up and makes one. going forward with everything digital this will be the only filter anyone will buy. All the others dont make sense anymore. But anyone using an old Leica lens on any future bodies will want this A36 slideon. They could sell quite a few I'm sure... Link to post Share on other sites More sharing options...
luigi bertolotti Posted July 20, 2007 Share #7  Posted July 20, 2007 Advertisement (gone after registration) >can be found an IRUV of this kind? No. That's one of the problems. I hope one of the filter makers wakes up and makes one. going forward with everything digital this will be the only filter anyone will buy. All the others dont make sense anymore. But anyone using an old Leica lens on any future bodies will want this A36 slideon. They could sell quite a few I'm sure...  ... for savvy collectors of little Leitz accessories... it came to my mind that some solution would exist... and searching between my various gear I found the SOOGZ / 13154 : an A36 clamp on ring that accepts the E39 filters. Hunting season started for SOOGZs ! Go go ! One for sale in Italy for Euro 60 ! at  Newoldcamera - Home page  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/29300-summar-filter-thread-size-and-pitch/?do=findComment&comment=310062'>More sharing options...
jlancasterd Posted July 20, 2007 Share #8  Posted July 20, 2007 I've been using my Summar on an R-D1 and now on the M8. In order to get the best results you have to use one of these B&W 486 UV/IR filters. Problem is I dont know which filter size and thread pitch that fits onto the Summar. Someone mentioned that it's a 34mm but I wouldnt know for sure... It seems Foto Huppert has a 34mm x 0.5 I could buy.. Does anyknow know? Thanks  Have you thought of buying a 34mm-39mm stepping ring? You could then use the 'standard' Leica filter - and also mount a 39mm lens hood.  SRB-Griturn (SRB-GRITURN LTD) in UK has a good range and will make odd sizes to special order. Link to post Share on other sites More sharing options...
Philippe D. Posted July 20, 2007 Share #9  Posted July 20, 2007 But anyone using an old Leica lens on any future bodies will want this A36 slideon.I wonder if any manufacturer would bother to do that. The solution given by Luigi is excellent. But if you madly want an IR filter on A36 mount, you could take a new E39 IR, let the glass be re-cut down to Ø34mm by a optician an put it in replacement of the old one.  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/29300-summar-filter-thread-size-and-pitch/?do=findComment&comment=310071'>More sharing options...
Jeffery Posted September 11, 2011 Share #10 Â Posted September 11, 2011 A36 IR filters can be had on ebay, I have one that holds back about 5 stops of light. Link to post Share on other sites More sharing options...
jc_braconi Posted September 11, 2011 Share #11 Â Posted September 11, 2011 A36 IR filters can be had on ebay, I have one that holds back about 5 stops of light. Â UV/IR, we are speaking about. Link to post Share on other sites More sharing options...
Guest Ron (Netherlands) Posted September 11, 2011 Share #12 Â Posted September 11, 2011 A36 IR filters can be had on ebay, I have one that holds back about 5 stops of light. Â The OP means an IR blocking filter, not an IR-passing filter Link to post Share on other sites More sharing options...
